• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Select a Text from AutoCAD and to Display in C# windows forms
    601 Views, 8 Replies
    03-02-2012 01:21 AM
    Dear All,
    Season greetings to all experts,
    with respect to above subject,
    using System.Runtime.InteropServices;
    using Autodesk.AutoCAD.Interop;
    privatevoid button2_Click(object sender, EventArgse)
    AcadApplication AcadApp = new Autodesk.AutoCAD.Interop.AcadApplication();
    AcadDocument doc1 = AcadApp.Documents.Open("c:\\test.dwg");
    AcadApp.Visible =true;
    AcadApp.ZoomExtents();
    double[] startPoint = newdouble[3];
    double[] endPoint = newdouble[3];
    startPoint[0] = 0; startPoint[1] = 0; startPoint[2] = 0;
    endPoint[0] = 20; endPoint[1] = 20; endPoint[2] = 0;
    AcadSelectionSet ssetObj = AcadApp.ActiveDocument.SelectionSets.Add("ss1");
    ssetObj.Select(Autodesk.AutoCAD.Interop.Common.
    AcSelect.acSelectionSetCrossingPolygon,startPoint,endPoint,Type.Missing, Type.Missing);
    the idea is to select the AutoCAD text by crossingPolygon and then to display the selected text in the C# windows form label1.text.
    Could you please help for this above request.
    Thanks in Advance.
    regards,
    Micky.
    Please use plain text.
    ADN Support Specialist
    Balaji_Ram
    Re: Select a Text from AutoCAD and to Display in C# windows forms
    03-02-2012 03:13 AM in reply to: Micky_1
    Hi Micky,
    Greetings to you too :smileyhappy:
    Will a pure .Net API route suit your needs ? You will not need the COM API for this :
    Here is a sample code :
                Document doc = Application.DocumentManager.MdiActiveDocument;
                Database db = doc.Database;
                Editor ed = doc.Editor;
                PromptSelectionOptions pso = new PromptSelectionOptions();
                pso.MessageForAdding = "\nSelect the entities";
                pso.SingleOnly = false;
                PromptSelectionResult psr = ed.GetSelection(pso);
                if (psr.Status != PromptStatus.OK) return;
                SelectionSet ss = psr.Value;
                foreach (SelectedObject selectedObj in ss)
                    switch (selectedObj.SelectionMethod)
                        case SelectionMethod.Crossing:
                            CrossingOrWindowSelectedObject crossingWindSelectedObj = selectedObj as CrossingOrWindowSelectedObject;
                            break;
     The SelectionMethod enum has other values for Window selection and so on. You can check it out yourself.
    Balaji
    Developer Technical Services
    Autodesk Developer Network
    03-02-2012 06:55 AM in reply to: Balaji_Ram
    The OP is obviously doing a stand-alone EXE app that automate AutoCAD (or the OP would not have to have code "new AcadApplication();" , thus cannot use .NET API.
    To OP:
    In your Select() method, you only pass in 2 points, which cannot form a polygon, thus, the first argument of the Select() method should be acSelectionSetFence.
    Since your selecting target is text, it would be better to supply a selection filter (the last 2 arguments of the Select() method).
    Anyway, assume the Select() method does return a set of AcadEnity, you simply loop through the SelectionSet to retrieve test string, like this:
    StringBuillder txt=new StringBuilder();
    foreach (object ent in ssetObj)
        AcadText t=ent as AcadText
        if (T!=null)
            txt.Append(t.TextString + "\n");
    //Show the text clollected in message box, or in your form.
    MessageBox.Show(t.ToString());
    Of course, if your selection target alos include MText, then you need to deal with it accordingly.
    03-02-2012 07:06 AM in reply to: Balaji_Ram
    Dear Mr.Balaji,
    Season Greetings,
    Thanks for your quick response,
    I am a beginer for .Net C#, that's why I am struggling a bit.
    In my codings I have some error in crossingpolygon selection method, rest everything working well.
    I am in need of 2 things,
    1. select a Text from AutoCAD by crossingpolygon method,
    2. store it in a string varible to display in C# windows forms.
    Could you please help me for this above request,
    I am trying hard to learn this .Net, I have a big hope that as soon as possible i will be getting a clear understanding of .net.
    Thanks & regards,
    Micky.
    Hallex
    03-02-2012 07:16 AM in reply to: Micky_1
    If you're using Interop better yet to define variables explicitly
    before you will be pulling them to the method / function
    From other hand you confused the selection mode
    try this code snip instead and tell us about result after :smileyhappy:
    {code}
    object miss = Type.Missing;
    Autodesk.AutoCAD.Interop.Common.AcSelect mode = AcSelect.acSelectionSetCrossing;
    ssetObj.Select(mode, startPoint, endPoint, miss, miss);
    MessageBox.Show(ssetObj.Count.ToString());{code}
    ~'J'~
    03-02-2012 07:17 AM in reply to: norman.yuan
    Dear Mr. Norman,
    Season Greetings,
    thanks for your response,
    for crossingpolygon selection method I using bottom left corner and top right corner only,
    Could you please see my reply post to Mr. Balaji, that's my problem and I got struck.
    Thanks & regards,
    Micky.
    03-02-2012 07:42 AM in reply to: Micky_1
    OK, simply call
    ssetobj.Select(acSelectionSetWindow, startPoint, endPoint,....)
    chiefbraincloud
    03-02-2012 10:24 AM in reply to: norman.yuan
    or rather acSelectionSetCrossing, but not acSelectionSetCrossingPolygon.
    03-02-2012 07:08 PM in reply to: Hallex
    Dear Mr. Hallex,
    Thanks very much for your kindness & support, the code is working well.
    where I will get reference or help file for the all the methods?
    for examples :
    [object filter Type = Type.missing] --- where to find examples or help files?
    [object filter Data = Type.missing]--- where to find examples or help files?
    for examples :
    AcadDocument doc1 = acApp.Documents.Open(textBox1.Text);
    In open method,
    I have given only the file name, if I wnat to give other two inputs then how?
    so where I will get reference or help files for all the methods.
    best regards,
    Micky.
