.NET
Natalie-C
Message 11 of 12 (61 Views)
Re: Searching for text
08-11-2006 06:36 AM in reply to: Natalie-C
That worked perfectly!!!
Thanks a lot.......
Member
simon.wood
Message 12 of 12 (61 Views)
08-13-2006 12:56 PM in reply to: Natalie-C
I use this code to get text, you could identify the k string
If TypeOf entity Is Autodesk.AutoCAD.DatabaseServices.MText Then
TextBox1.Text += "*MTEXT FOUND " & vbCrLf
Dim Txt As Autodesk.AutoCAD.DatabaseServices.MText = entity
TxtFound = TxtFound + 1
Dim k
k = Txt.Contents
TextBox1.Text += "Contents " & k.ToString & vbCrLf & vbCrLf
TextFnd(1, TxtFound) = k.tostring
k = Txt.Location
TextBox1.Text += "Location " & k.ToString & vbCrLf
Dim Spl
Spl = Mid(k.tostring, 2, Len(k.tostring) - 2)
TextBox1.Text += "SPLIT" & Spl & vbCrLf
Dim sa() As String
sa = Split(Spl, ",", -1)
TextFnd(0, TxtFound) = TxtFound
TextFnd(2, TxtFound) = sa(0)
TextFnd(3, TxtFound) = sa(1)
End If
You are not logged in.
Ask the Community
