.NET
Search block by name
2 REPLIES 2
TesiferSrl
719 Views, 2 Replies
Hi at all, my name is Daniele.
I started to develop autocad's application with .Net framework.
But i have some trouble, particularly when i try to find a block by name (not like id).
I would take a block by name, instead to get all block and find one with comparison.
How can resolve this problem?
Thank's very much, and sorry for my bad english
Daniele
2 REPLIES 2
Hallex
in reply to: TesiferSrl
Try this code, not seriously tested though
This will select all blocks by name on the current layout
        [CommandMethod("AllBlockByName","abb", CommandFlags.Modal)]
        public void GetAllBlockRefsByName()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            ObjectIdCollection objIds = new ObjectIdCollection();
            string ctab = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("ctab").ToString();
            string blockname = ed.GetString("\nEnter a block name: ").StringResult;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                string bname = string.Concat( blockname,",*`U*");
                TypedValue[] tvs = new TypedValue[] {
              new TypedValue(-4, "<and"),
              new TypedValue(0, "insert"),
              new TypedValue(2, bname),
              new TypedValue(410, ctab),
              new TypedValue(-4, "and>")
                SelectionFilter sf = new SelectionFilter(tvs);
                PromptSelectionResult psr = ed.SelectAll(sf);
                if (psr.Status != PromptStatus.OK)
                    ed.WriteMessage("\nWrong selection\n");
                    return;
                ed.WriteMessage("\nCount of  selected block: {0}", psr.Value.Count);
                BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                BlockTableRecord btrec = null;
                string brefname= "";
                foreach (SelectedObject selobj in psr.Value)
                    DBObject obj = (DBObject)tr.GetObject(selobj.ObjectId, OpenMode.ForRead,false) ;
                    BlockReference bref = obj as BlockReference;
                    if (bref == null) continue;
                    if (!bref.IsDynamicBlock)
                        brefname = bref.Name;
                    else
                        btrec = (BlockTableRecord)tr.GetObject(bref.DynamicBlockTableRecord, OpenMode.ForRead, false, true);
                        brefname = btrec.Name;
                    if (brefname.CompareTo(blockname) == 0)
                        objIds.Add(bref.ObjectId);
                        for (int n=0;n< objIds.Count;n++)
                        DBObject ent = (DBObject)tr.GetObject(objIds[n], OpenMode.ForRead, false);
                        BlockReference btref = ent as BlockReference;
                        ed.WriteMessage("\nPosition: {0}\n", btref.Position);
                        //  [  do your rest work with block instances here  ]  //
                tr.Commit();
 Here is better explained article thanks to Stephen Preston:
http://adndevblog.typepad.com/autocad/2012/06/finding-all-block-references-of-a-dynamic-block.html
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
fieldguy
Hi Daniele - welcome aboard!
Please use the search tool 1st - this question is very common.  Enter your subject as is and start reading.
”Boost
