.NET
Giri_kani
Message 1 of 4 (149 Views)
Scaling Multiple Objects in .Net
149 Views, 3 Replies
03-28-2014 10:29 PM
I have a objectid collection, I need to scale all tha objects as the scale factor 20.
The object id collection have line,text,block and so on.
How to scale those objects using .net?
Please guide me.
Valued Contributor
cdinten
Message 2 of 4 (125 Views)
Re: Scaling Multiple Objects in .Net
03-29-2014 12:25 AM in reply to: Giri_kani
using Entity.TransformBy() method, all you have to do is constructing a transform matrix that dealing with scaling
Hallex
Message 3 of 4 (127 Views)
03-29-2014 12:33 AM in reply to: Giri_kani
Try this example borrowed from Jeff_H
        ''borrowed from Jeff_H
        <CommandMethod("Sc20", CommandFlags.UsePickSet And CommandFlags.Redraw)> _
        Public Shared Sub ScaleObjects()
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim ed As Editor = doc.Editor
            Dim db As Database = doc.Database
            Dim ppo As New PromptPointOptions("")
            ppo.Message = vbLf & "Pick a center of scaling : "
            ppo.AllowNone = False
            Dim ppr As PromptPointResult
            ppr = ed.GetPoint(ppo)
            If ppr.Status <> PromptStatus.OK Then
                Return
            End If
            Dim pc As Point3d = ppr.Value
            Try
                Using doclock As DocumentLock = doc.LockDocument()
                    Using tr As Transaction = doc.TransactionManager.StartTransaction()
                        Dim btr As BlockTableRecord = CType(tr.GetObject(db.CurrentSpaceId, OpenMode.ForRead), BlockTableRecord)
                        Dim pso As New PromptSelectionOptions
                        pso.MessageForRemoval = vbLf & "Nothing sdelected, try again."
                        pso.MessageForAdding = vbLf & "Select Objects to scale: "
                        pso.RejectObjectsOnLockedLayers = True
                        pso.RejectObjectsFromNonCurrentSpace = True
                        Dim res As PromptSelectionResult = ed.GetSelection(pso)
                        If res.Status <> PromptStatus.OK Then Return
                        Dim idArr() As ObjectId = res.Value.GetObjectIds()
                        btr.UpgradeOpen()
                        Dim ids As ObjectIdCollection = New ObjectIdCollection
                        For Each id As ObjectId In idArr
                            ids.Add(id)
                        Next
                        For Each id In ids
                            Dim ent As Entity = TryCast(tr.GetObject(id, OpenMode.ForRead, False), Entity)
                            If ent Is Nothing Then Return
                            If Not ent.IsWriteEnabled Then ent.UpgradeOpen()
                            ent.TransformBy(Matrix3d.Scaling(20.0, pc))
                        Next
                        tr.Commit()
                    End Using
                End Using
            Catch ex As Autodesk.AutoCAD.Runtime.Exception
                Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.Message & vbLf & ex.StackTrace)
            Finally
            End Try
        End Sub
Giri_kani
Message 4 of 4 (77 Views)
04-02-2014 12:48 AM in reply to: Hallex
This is working fine..
Thank you so much..
You are not logged in.
Ask the Community
