.NET
Scale factor issue when inserting Image.
1 REPLY 1
396 Views, 1 Reply
Hi
I am asking user for scale factor and insertion point. but the actual image alway display width and height as the scale value, if i insert value of 5 for scale factor width and height will be 5 but not according to coordinates system.
 but if i insert the same image manualy width and height are calculated by autocad according to scale factor before insertion.
double scale = promptDoubleResult.Value;
 var xAxis = new Vector3d(scale, 0, 0);
 var yAxis = new Vector3d(0, scale, 0);
 var ucs = document.Editor.CurrentUserCoordinateSystem;
using (Transaction trans = database.TransactionManager.StartTransaction())
                        RasterImageDef rasterImageDef = new RasterImageDef();
                        rasterImageDef.SourceFileName = imagePath;
                        rasterImageDef.Load();
                        ObjectId imgDicId = RasterImageDef.GetImageDictionary(database);
                        if(imgDicId.OldIdPtr == new IntPtr(0))
                            imgDicId = RasterImageDef.CreateImageDictionary(database);
                        DBDictionary imgDict = trans.GetObject(imgDicId, OpenMode.ForWrite, false, true) as DBDictionary;
                        if (imgDict.Contains(BlockName))
                            return false;
                        else
                            imgDict.SetAt(BlockName, rasterImageDef);
                            trans.AddNewlyCreatedDBObject(rasterImageDef, true);
                            // now add the REAL raster image reference
                            RasterImage rasterImg = new RasterImage();
                            rasterImg.ImageDefId = rasterImageDef.ObjectId;
                            rasterImg.Orientation = new CoordinateSystem3d(insertionPoint.TransformBy(ucs),xAxis.TransformBy(ucs),yAxis.TransformBy(ucs));
                            rasterImg.Rotation = rotationAngle;
                            BlockTable bt = (BlockTable)trans.GetObject(database.BlockTableId, OpenMode.ForRead, false, true);
                            BlockTableRecord btr = (BlockTableRecord)trans.GetObject(database.CurrentSpaceId, OpenMode.ForWrite, false, true);
                            ObjectId rasterImgId = btr.AppendEntity(rasterImg);
                            trans.AddNewlyCreatedDBObject(rasterImg, true);
                            rasterImg.AssociateRasterDef(rasterImageDef);
                            trans.Commit();
Thanks for your help.
1 REPLY 1
SENL1362
I have seen the same issues in VBA some years ago.
Currently no C# sample available but have a look at the next code might help
Notice i had to set the scale twice.
                With imageRef
'                    On Error Resume Next
'                        .ImageFile = ".\" & fs.GetFileName(tifPathname)
'                    On Error GoTo EndOfProc
                    .Origin = imagePos
                    .ScaleFactor = imageScale
                    .Rotation = imageAngle
                    .ScaleFactor = 1
                    acadDoc.Layers.Add "Raster"
                    .layer = "Raster"
                    .Transparency = True
                        .name = fs.GetBaseName(tifPathname)
                End With
Also compare the DPI for both the manual and youre program result.
Drawing Units may influence the behaviour as well.
And besure to have the xDPI==yDPI otherwise youre raster may not be editable in RasterDesign.
”Boost
