.NET
Valued Contributor
RamanSBV
Message 1 of 4 (292 Views)
Saving current drawing file.
292 Views, 3 Replies
08-21-2012 09:59 PM
Please help me on.. How to save current drawing file using save method.
Raman
_gile
Message 2 of 4 (268 Views)
Re : Saving current drawing file.
08-22-2012 07:53 AM in reply to: RamanSBV
Did you look at: AutoCAD .NET Devemopper's Guide > Control the AutoCAD environment > Create, Open, Save and Close drawings > Create and Close a drawing ?
Gilles Chanteau
chiefbraincloud
Message 3 of 4 (267 Views)
Re: Saving current drawing file.
08-22-2012 07:55 AM in reply to: RamanSBV
The Database.Save method is "Not Implemented" at least through 2012.  It still says the same thing in the 2013 docs.
You have to use SaveAs, or if the drawing is open in the editor, and you are closing it after, I believe the Document.CloseAndSave method does work.  I just searched, and can't find any of my code that uses it, but I think it used it once in the past, but eventually changed that code to work on side databases instead of opening files into the editor.
Valued Mentor
jeff
Message 4 of 4 (257 Views)
08-22-2012 01:45 PM in reply to: RamanSBV
http://www.theswamp.org/index.php?topic=42016.msg471429#msg471429
It is nice as in link to make it an extension method so you can just use Document.Save().
You can also find your answers @ TheSwamp
You are not logged in.
Ask the Community
