.NET
Saving active drawing file.
10 REPLIES 10
Message 1 of 11
2410 Views, 10 Replies
Could please any body give the suggestion on how to save active drawing file with filename..
Raman
10 REPLIES 10
Message 2 of 11
BrentBurgess1980
Take a look at the Database.SaveAs Method.
Using AcApp = Autodesk.AutoCAD.ApplicationServices.Application;
//Inside your function
AcApp.DocumentManager.MdiActiveDocument.Database.SaveAs();
Message 3 of 11
in reply to: BrentBurgess1980
Thanks for your post
Please suggest me, how i can give the file name for un saved file.
Raman
Message 4 of 11
Alfred.NESWADBA
if you want just to save a drawing:
  ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.Save
In this case you should first compare it the file already has an assigned name!
If you want to give the file a new name the use:
  Dim tFilename as String = "C:\TEMP\XX.DWG"
  Dim tVersion as DatabaseServices.DwgVersion = DatabaseServices.DwgVersion.Current
  ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.SaveAs(tFileName,tVersion)
In this case yo should first check that the file does not exist before you start save!
...assuming you have these Import-settings on top of your file:
Imports Autodesk.AutoCAD
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 5 of 11
in reply to: Alfred.NESWADBA
I am getting below error while saving autocad file with file name. Please help me on this.eRROR
Message 6 of 11
Alfred.NESWADBA
to be honest ... can you read the text on your screenshot within your post?
If so let me know what browser you are using.
- alfred -
Alfred NESWADBA
Message 7 of 11
From what little I could make out of the screenshot, it looks like it was "eWasOpenForWrite". I could be mistaken though...
Message 8 of 11
Message 9 of 11
BrentBurgess1980
You might need to lry locking the document
using (DocumentLock dLock = AcApp.DocumentManager.MdiActiveDocument.LockDocument())
                string tFilename = @"C:\TEMP\XX.DWG";
                Autodesk.AutoCAD.DatabaseServices.DwgVersion tVersion = Autodesk.AutoCAD.DatabaseServices.DwgVersion.Current;
                AcApp.DocumentManager.MdiActiveDocument.Database.SaveAs(tFilename, tVersion);
Message 10 of 11
Alfred.NESWADBA
have you installed the latest servicepacks? Did you run any code before you try to save and does this error also occure if yo udefine a command just doing that save?
To the error itself: it may not be a coding-fault as >>>this search<<< shows multiple appearances of this message.
- alfred -
Alfred NESWADBA
Message 11 of 11
Hallex
You might be want to try another syntax as well:
db.SaveAs(SaveFileName, false, DwgVersion.Current, db.SecurityParameters); //'<--- tested on A2009 and A2010
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
”Boost
