• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Valued Contributor
    RamanSBV
    Saving active drawing file.
    221 Views, 10 Replies
    05-17-2012 11:13 PM
    Could please any body give the suggestion on how to save active drawing file with filename..
    Raman
    Please use plain text.
    BrentBurgess1980
    Re: Saving active drawing file.
    05-17-2012 11:35 PM in reply to: RamanSBV
    Take a look at the Database.SaveAs Method.
    Using AcApp = Autodesk.AutoCAD.ApplicationServices.Application;
    //Inside your function
    AcApp.DocumentManager.MdiActiveDocument.Database.SaveAs();
    Valued Contributor
    RamanSBV
    05-17-2012 11:36 PM in reply to: BrentBurgess1980
    Thanks for your post
    Please suggest me, how i can give the file name for un saved file.
    Raman
    05-17-2012 11:38 PM in reply to: RamanSBV
    if you want just to save a drawing:
      ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.Save
    In this case you should first compare it the file already has an assigned name!
    If you want to give the file a new name the use:
      Dim tFilename as String = "C:\TEMP\XX.DWG"
      Dim tVersion as DatabaseServices.DwgVersion = DatabaseServices.DwgVersion.Current
      ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.SaveAs(tFileName,tVersion)
    In this case yo should first check that the file does not exist before you start save!
    ...assuming you have these Import-settings on top of your file:
    Imports Autodesk.AutoCAD
    HTH, - alfred -
    Alfred NESWADBA
    Valued Contributor
    RamanSBV
    05-18-2012 12:15 AM in reply to: alfred.neswadba
    I am getting below error while saving autocad file with file name. Please help me on this.eRROR
    05-18-2012 12:17 AM in reply to: RamanSBV
    to be honest ... can you read the text on your screenshot within your post?
    If so let me know what browser you are using.
    - alfred -
    Alfred NESWADBA
    BrentBurgess1980
    05-18-2012 12:24 AM in reply to: alfred.neswadba
    From what little I could make out of the screenshot, it looks like it was "eWasOpenForWrite". I could be mistaken though...
    Valued Contributor
    RamanSBV
    05-18-2012 12:29 AM in reply to: alfred.neswadba
    BrentBurgess1980
    05-18-2012 12:38 AM in reply to: RamanSBV
    You might need to lry locking the document
    using (DocumentLock dLock = AcApp.DocumentManager.MdiActiveDocument.LockDocument())
                    string tFilename = @"C:\TEMP\XX.DWG";
                    Autodesk.AutoCAD.DatabaseServices.DwgVersion tVersion = Autodesk.AutoCAD.DatabaseServices.DwgVersion.Current;
                    AcApp.DocumentManager.MdiActiveDocument.Database.SaveAs(tFilename, tVersion);
    05-18-2012 12:42 AM in reply to: RamanSBV
    have you installed the latest servicepacks? Did you run any code before you try to save and does this error also occure if yo udefine a command just doing that save?
    To the error itself: it may not be a coding-fault as >>>this search<<< shows multiple appearances of this message.
    - alfred -
    Alfred NESWADBA
