• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Valued Contributor
    Saving a drawing that is open but not active
    142 Views, 3 Replies
    11-15-2012 10:35 AM
    Any trick to using dwgDB.saveas on a drawing database that the user has open but NOT current on his screen?
    For example, the user has DWG1 open and DWG2 open and currently active, my program modifies DWG1 (inactive) and when the program tries to run...
    dwg1DB.SaveAs(filename, true, DwgVersion.Current, dwg1DB.SecurityParameters)
    it errors with an elock violation, even though I lock the document with dwg1DOC.LockDocument before I try to save and unlock it after.
    The same code runs fine on the current document so at this time I just ended making the other document current just to save it then switch back to previously current document.
    What am I missing to save a document that is open but not current?
    Please use plain text.
    Member
    Re: Saving a drawing that is open but not active
    11-18-2012 03:21 PM in reply to: CommCorp
    As I understand it, since the Document is already open in the Editor, you'd either have to have the Editor save the Document via SendStringToExecute(), or consider an extension method via the AcadDocument.Save() method.
    Here are a couple of example threads:
    Implementing a "Quick SaveAs" command in AutoCAD using .NET
    Database.SaveAs() Problems
    "A bad mood is like bad breath. Nobody likes a person with bad breath" - Prager
    "First tell the truth, then give your opinion" - Prager
    "One who is offended by truth, has no place among those who seek wisdom" - RenderMan
    Valued Contributor
    11-19-2012 08:05 AM in reply to: CommCorp
    Thanks!
    AcadDocument.save() works great regardless of whether the document is current or not.
    Member
    12-05-2012 06:32 PM in reply to: CommCorp
    CommCorp wrote:
    Thanks!
    You're welcome; I'm happy to help.
