.NET
Valued Contributor
Message 1 of 4 (199 Views)
Saving a drawing that is open but not active
199 Views, 3 Replies
11-15-2012 10:35 AM
Any trick to using dwgDB.saveas on a drawing database that the user has open but NOT current on his screen?
For example, the user has DWG1 open and DWG2 open and currently active, my program modifies DWG1 (inactive) and when the program tries to run...
dwg1DB.SaveAs(filename, true, DwgVersion.Current, dwg1DB.SecurityParameters)
it errors with an elock violation, even though I lock the document with dwg1DOC.LockDocument before I try to save and unlock it after.
The same code runs fine on the current document so at this time I just ended making the other document current just to save it then switch back to previously current document.
What am I missing to save a document that is open but not current?
Member
Message 2 of 4 (169 Views)
Re: Saving a drawing that is open but not active
11-18-2012 03:21 PM in reply to: CommCorp
As I understand it, since the Document is already open in the Editor, you'd either have to have the Editor save the Document via SendStringToExecute(), or consider an extension method via the AcadDocument.Save() method.
Here are a couple of example threads:
Implementing a "Quick SaveAs" command in AutoCAD using .NET
Database.SaveAs() Problems
"A bad mood is like bad breath. Nobody likes a person with bad breath" - Prager
"First tell the truth, then give your opinion" - Prager
"One who is offended by truth, has no place among those who seek wisdom" - RenderMan
Valued Contributor
Message 3 of 4 (147 Views)
11-19-2012 08:05 AM in reply to: CommCorp
Thanks!
AcadDocument.save() works great regardless of whether the document is current or not.
Member
Message 4 of 4 (113 Views)
12-05-2012 06:32 PM in reply to: CommCorp
CommCorp wrote:
Thanks!
You're welcome; I'm happy to help.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
