.NET
Valued Contributor
GrzesiekGP
Message 11 of 20 (375 Views)
Re: Save some variables into DWG file - how? C#.
09-12-2012 11:20 PM in reply to: _gile
Do you have some example of code for XRecords and DBDictionary?
I'm searching, but it hard to find what I need.
_gile
Message 12 of 20 (370 Views)
09-12-2012 11:55 PM in reply to: GrzesiekGP
Here're two little example to set and get xrecord data (ResultBuffer as for Xdata) in a named dictionary child of the root NamedObjectsDictionary (NOD).
        /// <summary>
        /// Add or edit a Xrecord data in a named dictionary (the dictionary and xrecord are created if not already exist)
        /// </summary>
        /// <param name="dictName">The dictionary name</param>
        /// <param name="key">the xrecord key</param>
        /// <param name="resbuf">the xrecord data</param>
        public void SetXrecord(string dictName, string key, ResultBuffer resbuf)
            Document doc = acadApp.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                DBDictionary NOD =
                    (DBDictionary)tr.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForRead);
                DBDictionary dict;
                if (NOD.Contains(dictName))
                    dict = (DBDictionary)tr.GetObject(NOD.GetAt(dictName), OpenMode.ForWrite);
                else
                    dict = new DBDictionary();
                    NOD.UpgradeOpen();
                    NOD.SetAt(dictName, dict);
                    tr.AddNewlyCreatedDBObject(dict, true);
                Xrecord xRec = new Xrecord();
                xRec.Data = resbuf;
                dict.SetAt(key, xRec);
                tr.AddNewlyCreatedDBObject(xRec, true);
                tr.Commit();
        /// <summary>
        /// Gets an xrecord data in a named dictionary
        /// </summary>
        /// <param name="key">The xrecord key</param>
        /// <returns>The xrecord data or null if the dictionary or the xrecord do not exist</returns>
        public ResultBuffer GetXrecord(string dictName, string key)
                DBDictionary NOD =
                if (!NOD.Contains(dictName))
                    return null;
                DBDictionary dict = tr.GetObject(NOD.GetAt(dictName), OpenMode.ForRead) as DBDictionary;
                if (dict == null || !dict.Contains(key))
                    return null;
                Xrecord xRec = tr.GetObject(dict.GetAt(key), OpenMode.ForRead) as Xrecord;
                if (xRec == null)
                    return null;
                return xRec.Data;
Gilles Chanteau
Valued Contributor
GrzesiekGP
Message 13 of 20 (365 Views)
09-13-2012 12:09 AM in reply to: _gile
Thank you very much for help.
Please tell me one more thinkg. Am I able to get specified TypedValue from ResultBuffer?
If not I suppose that the best way would be to put all values into dictionary<int,string>. Am I right?
_gile
Message 14 of 20 (360 Views)
09-13-2012 12:20 AM in reply to: GrzesiekGP
As for Xdata you have to use a ResultBuffer to set data in a Xrecord and the Xrecord.Data property is a ResultBuffer.
Assuming your xrecord contains a single data of type String, you can get the data this way:
ResultBuffer resbuf = GetXrecord(theDictName, theXrecKey);
string theFirstData =(string) resbuf.AsArray()[0].Value;
Gilles Chanteau
Valued Contributor
GrzesiekGP
Message 15 of 20 (356 Views)
09-13-2012 12:53 AM in reply to: _gile
Thank you for the help :smileyhappy:
Valued Contributor
GrzesiekGP
Message 16 of 20 (347 Views)
09-13-2012 02:58 AM in reply to: _gile
Please let me know one more thing.
Am I able to get all keys from my dictionary?
I would to allow user to select from which Key in my dictionary user want to see his variables.
In example:
SetXrecord("myDict", "keysFirst", rb);
SetXrecord("myDict", "keysSecond", rb);
SetXrecord("myDict", "keysThird", rb);
And now I want to list: keysFirst,keysSecond,keysThird.
Ok, I've got it:
 List<string> _keys = new List<string>();
                foreach (DBDictionaryEntry entry in dict)
                    _keys.Add(entry.Key);
                return string.Join(",", _keys.ToArray());
Valued Contributor
GrzesiekGP
Message 17 of 20 (332 Views)
09-13-2012 11:15 AM in reply to: GrzesiekGP
One more to do :smileyhappy: Removing keys :smileytongue:
I have this code:
public static void RemoveXrecord(string dictName, string key)
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            DocumentLock dl = doc.LockDocument(DocumentLockMode.ProtectedAutoWrite, null, null, true);
            using (dl)
                    DBDictionary NOD = (DBDictionary)tr.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForRead);
                        return;
                    DBDictionary dict = tr.GetObject(NOD.GetAt(dictName), OpenMode.ForWrite) as DBDictionary;
                        return;
                    dict.Remove(key);
 But key still exist after removing :smileysad:
_gile
Message 18 of 20 (328 Views)
09-13-2012 11:51 AM in reply to: GrzesiekGP
It looks like you forgot to call: tr.Commit();
Gilles Chanteau
Valued Contributor
GrzesiekGP
Message 19 of 20 (323 Views)
09-13-2012 11:56 AM in reply to: _gile
Lol, I'm blind :smileytongue:
Thank you!
Active Contributor
RichardCammeray
Message 20 of 20 (305 Views)
09-13-2012 04:15 PM in reply to: GrzesiekGP
Once you work with Dictionaries very useful is ArxDbd utility for testing.
http://otb.manusoft.com/2009/09/arxdbg-utility.htm
You are not logged in.
Ask the Community
