.NET
udo
Active Member
udo
Message 1 of 4 (458 Views)
Save a password protected drawing without password with VB.NET
458 Views, 3 Replies
05-09-2012 06:57 AM
our drawings are protected by a password.
We have a VB.NET programm to export a drawing without password.
Dim securityPar As New SecurityParameters(Nothing, Nothing, Nothing, Nothing, Nothing, Nothing, Nothing, Nothing, Nothing, Nothing, Nothing)
doc.Database.SaveAs("C:\Temp\Test.DWG", False, DwgVersion.Current, securityPar)
doc.CloseAndSave("C:\Temp\Test.DWG")
In AutoCAD Architecture 2009 (Win XP) it works fine.
In AutoCAD Architecture 2011 (Win 7) the drawing is still password protected.
Thank you for help,
Udo
Moderator
Alexander.Rivilis
Message 2 of 4 (453 Views)
Re: Save a password protected drawing without password with VB.NET
05-09-2012 08:27 AM in reply to: udo
With help of ObjecARX (native) you can clear password protection: http://forums.autodesk.com/t5/Autodesk-ObjectARX/any-way-to-remove-password-from-a-dwg/m-p/3429797#M...
I've not found corresponding method AutoCAD .NET API. IMHO you have to P/Invoke setSecurityParams method.
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Moderator
Alexander.Rivilis
Message 3 of 4 (439 Views)
05-09-2012 02:27 PM in reply to: Alexander.Rivilis
Try this code (minimum testing with AutoCAD 2012 x86):
using System;
using System.Runtime.InteropServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
// This line is not mandatory, but improves loading performances
[assembly: CommandClass(typeof(Rivilis.ClearPassword))]
namespace Rivilis
    // This class is instantiated by AutoCAD for each document when
    // a command is called by the user the first time in the context
    // of a given document. In other words, non static data in this class
    // is implicitly per-document!
    public class ClearPassword
        [StructLayout(LayoutKind.Sequential)]
        // From dbsecurity.h
        public struct SecurityParams
            public uint cbSize;
            public uint ulFlags;    // see enum above for flag values
            // data relevant to password protection
            public string wszPassword;
            public uint ulProvType;
            public string wszProvName;
            public uint ulAlgId;        // SECURITYPARAMS_ALGID_RC4
            public uint ulKeyLength;
            // data relevant to digital signatures
            public string wszCertSubject;
            public string wszCertIssuer;
            public string wszCertSerialNum;
            public string wszComment;
            public string wszTimeServer;
        [DllImport("acdb18.dll", CallingConvention = CallingConvention.ThisCall,
            EntryPoint = "?setSecurityParams@AcDbDatabase@@QAE_NPBUSecurityParams@@_N@Z")]
        static extern private bool setSecurityParamsX32(IntPtr db, ref SecurityParams pSecParams, bool bSetDbMod = true);
            EntryPoint = "?setSecurityParams@AcDbDatabase@@QEAA_NPEBUSecurityParams@@_N@Z")]
        static extern private bool setSecurityParamsX64(IntPtr db, ref SecurityParams pSecParams, bool bSetDbMod = true);
        static public bool setSecurityParams(Database db, ref SecurityParams parms, bool bSetDbMod = true)
            if (IntPtr.Size == 4) return setSecurityParamsX32(db.UnmanagedObject, ref parms, bSetDbMod);
                     else         return setSecurityParamsX64(db.UnmanagedObject, ref parms, bSetDbMod);
        [CommandMethod("ClearPWD", CommandFlags.Modal)]
        public void ClearPWD()
            Database db = HostApplicationServices.WorkingDatabase;
            SecurityParams parms = new SecurityParams();
            parms.cbSize = (uint)Marshal.SizeOf(parms);
            parms.ulFlags = 0; // Clear security flag
            setSecurityParams(db, ref parms);
For VB.NET you can convert C# code: http://www.developerfusion.com/tools/convert/csharp-to-vb/
udo
Active Member
udo
Message 4 of 4 (397 Views)
05-24-2012 12:24 AM in reply to: Alexander.Rivilis
Hello Alexander,
thank you! It works very fine in AutoCAD Architecture 2011.
Udo
You are not logged in.
Ask the Community
