.NET
SQL Server Express or higher?
2 REPLIES 2
wesbird
351 Views, 2 Replies
  I'm evaluation Vault 2014 now, how do I dertermine which versin of SQL Server I should use, Express, Standard, or higher? where is the best practise? in the number of document, like 10,000 files? or size of documents, 10 Tb files?
Thank you so much
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
2 REPLIES 2
Hallex
in reply to: wesbird
I use succesfully SQl Server 2008R2 with A2014
without problem (either with C# and lisp)
dgorsman
Is this a programming issue, or should it go under the dedicated Vault board?
”Boost
