.NET
Running Macro from Ribbon button
4 REPLIES 4
mnav
1047 Views, 4 Replies
Hi
I have created a ribbonbar in autocad 2012 using API and  c#.
On ribbon button i am executing a Command method which display a wizard for copying some files.
now i want to run a macro before excuting the ribbon button command methood.
which display a messagebox with yes and no
if user click yes command method will excutes itself and display wizard for copy files
if user click no command method will not execute and return.
this will allow user to use macro for customizing the file copy process.
can some body help how i can achive this.
thanks a lot.
4 REPLIES 4
Ed.Jobe
in reply to: mnav
Here's some info on prompting the user.
Ed
How to post your code.
mnav
in reply to: mnav
thanks for your reply but i want to run a macro not the editor prompt.  i want to run a macro which decide to continue with command of abort it.
any help how to run and macro from ribbon button and abort button command if you dont want to continue.#
thanks
mnav
in reply to: mnav
Got it..... here is the code if somebody looking for it
AcadApplication.RunMacro(@"C:\Test\AutocadVBA\NavTest.dvb!Module1.navTest");
thanks
Ed.Jobe
in reply to: mnav
Sorry, I misunderstood what you wanted. Your question sounded like you wanted the menu macro to prompt the user. You didn't ask on how to run a vba macro.
Ed
”Boost
