.NET
*Expert Elite*
arcticad
Message 1 of 6 (629 Views)
Accepted Solution
Run function as soon as .dll loads
629 Views, 5 Replies
03-29-2012 06:29 AM
Is there a way to run some code as soon as a .dll file is loaded without having to using lisp (command "Function_Name")?
Thank You.
(defun botsbuildbots() (botsbuildbots))
*Expert Elite*
Keith.Brown
Message 2 of 6 (627 Views)
Re: Run function as soon as .dll loads
03-29-2012 06:40 AM in reply to: arcticad
I am a beginning dotnet autocad programmer and use visual basic but I use this to run code when my dll is loaded.  I just grabbed it from the autodesk visual studio wizard.
        Implements IExtensionApplication
        Public Sub Initialize() Implements IExtensionApplication.Initialize
            ' Add one time initialization here
            ' One common scenario is to setup a callback function here that
            ' unmanaged code can call.
            ' To do this:
            ' 1. Export a function from unmanaged code that takes a function
            '    pointer and stores the passed in value in a global variable.
            ' 2. Call this exported function in this function passing delegate.
            ' 3. When unmanaged code needs the services of this managed module
            '    you simply call acrxLoadApp() and by the time acrxLoadApp
            '    returns  global function pointer is initialized to point to
            '    the C# delegate.
            ' For more info see:
            ' http:'msdn2.microsoft.com/en-US/library/5zwkzwf4(VS.80).aspx
            ' http:'msdn2.microsoft.com/en-us/library/44ey4b32(VS.80).aspx
            ' http:'msdn2.microsoft.com/en-US/library/7esfatk4.aspx
            ' as well as some of the existing AutoCAD managed apps.
            ' Initialize your plug-in application here
            Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
            ed.WriteMessage("Plugin Loaded successfully...")
        End Sub
        Public Sub Terminate() Implements IExtensionApplication.Terminate
            ' Do plug-in application clean up here
        End Sub
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
*Expert Elite*
arcticad
Message 3 of 6 (620 Views)
03-29-2012 06:49 AM in reply to: Keith.Brown
Awesome, Works great.
Thank You.
*Expert Elite*
chiefbraincloud
Message 4 of 6 (597 Views)
03-29-2012 12:57 PM in reply to: arcticad
I would have made the same suggestion, but with one caveat.  You need to be careful exactly what you try to do in the initialize routine, as AutoCAD my not be ready for certain things at that time, especially if you are demand loading on AutoCAD startup.
Valued Contributor
GrzesiekGP
Message 5 of 6 (476 Views)
11-04-2012 10:47 AM in reply to: arcticad
Hope someone can help me.
I want to check the license key (from user settings) in Initialize function, but when I set true/false for the global variable in this method, in commands I'm always getting false value. Why?
        private bool isLicensed;
        public bool Licensed
            get { return isLicensed; }
            set { isLicensed = value; }
void IExtensionApplication.Initialize()
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            ed.WriteMessage("Sprawdzanie licencji ... ");
            if (licenseKey == userKey)
                Licensed = true;
            else
                GPLicense gpl = new GPLicense();
                gpl.Show();
                Licensed = gpl.isValidate;
 private bool CheckLicense()
            if (!Licensed)
                ed.WriteMessage("Brak licencji!");
                gpl.Show();
                return Licensed;
            else
                return true;
        [CommandMethod("GC")]
        public void CleanLayer()
            if (!CheckLicense())
                return;
            GC.CleanLayer();
Valued Mentor
Message 6 of 6 (444 Views)
11-05-2012 07:34 PM in reply to: GrzesiekGP
Your command method and the properties of your class are instance members.
AutoCAD will create a seperate instance of your class for each document you use your command in.
Unless your data is document-specific, you should not be using non-static command methods or instance properties, you should either store that data in a separate class for which there is only one instance, without any non-static command methods (e.g., a singleton), or you should make everything static (the command methods and the properties they access).
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
