.NET
Distinguished Contributor
quigs
Message 1 of 4 (355 Views)
Ribbon load at startup
355 Views, 3 Replies
12-08-2012 10:39 AM
Hi there,
I have been using the ribbon api to create my custom ribbon.  I am
now attempting to load said rribbon at startup by placing the load
command into the initialize componant.  It isn't working.
Does any on have any ideas?
 Dim ribCntrl As Autodesk.Windows.RibbonControl = Autodesk.Windows.ComponentManager.Ribbon
        If ComponentManager.Ribbon Is Nothing Then
            Return
        End If
        For i As Integer = 0 To ribCntrl.Tabs.Count - 1
            If ribCntrl.Tabs(i).Id.Equals("My_Rib_ID") Then
                Return
            End If
        Next
        'add the tab
        Dim ribTab As New RibbonTab()
        ribTab.Title = "My New ribbon
        ribTab.Id = "My_Rib_ID"
        ribCntrl.Tabs.Add(ribTab)
        'create and add the panels
        addPanel1(ribTab)
        addPanel2(ribTab)
        addPanel3(ribTab)
        addPanel4(ribTab)
        addPanel5(ribTab)
        addPanel6(ribTab)
        addPanel7(ribTab)
        'set as active tab
        ribTab.IsActive = True
I seem to remember being told it's because the ribbon .dll hasn't yet started
at this point sso it has nothing to use to load it?
Any help would be appreciated.
Ta,
Maritn.
My name is Martin.. :smileyvery-happy:
Valued Mentor
DiningPhilosopher
Message 2 of 4 (345 Views)
Re: Ribbon load at startup
12-08-2012 12:09 PM in reply to: quigs
If the ribbon isn't loaded when your plug-in loads, you shouldn't try to load it.
When your plug-in loads, if it doesn't find the ribbon loaded, then you should add a handler to the RibbonService's RibbonPaletteSetCreated event. When the user activates the ribbon, your handler will be called and you can add your stuff then.
quigs
Message 3 of 4 (335 Views)
12-08-2012 03:53 PM in reply to: DiningPhilosopher
the ribben itself loads fine with the above code.  But loading at startup ecapes me.
I can't seem to work it out?
ADN Support Specialist
Balaji_Ram
Message 4 of 4 (296 Views)
12-11-2012 02:58 AM in reply to: quigs
Hi Martin,
Have you tried using the “Autodesk.Windows.ComponentManager.ItemInitialized” event as in this forum post ?
http://forums.autodesk.com/t5/NET/Autoloader-problem/td-p/3083488
Balaji
Developer Technical Services
Autodesk Developer Network
You are not logged in.
Ask the Community
