.NET
Member
winnes
Message 1 of 11 (403 Views)
Ribbon - Unhandled access violation reading 0x0000 exception
403 Views, 10 Replies
06-18-2013 02:00 AM
I have this Acad plugin (C#), where I simply create a Ribbon, Button on it that executes a Command.
Windows 7, AutoCAD 2013 all running x64.
Used the ObjectARX x64 Libraries for my references.
In my environment, everything works just fine, on my clients workstations... it shows 'Unhandled access violation reading 0x0000 exception'
Since client installed AutoCAD 2012 and then 2013, I tried a Repair, to no result.
Have verified all references, put all ObjectARX references, just to make sure, put debug lines in the code.
It crashes at first line:
Autodesk.Windows.RibbonControl ribbonControl = Autodesk.Windows.ComponentManager.Ribbon;
All other Commands seem to run just fine.
Any clue what could be the cause, what I could try more?
ADN Support Specialist
augusto.goncalves
Message 2 of 11 (379 Views)
Re: Ribbon - Unhandled access violation reading 0x0000 exception
06-18-2013 09:31 AM in reply to: winnes
Maybe is just a matter of timing...when is this code called? During startup?
Please also try with
          Autodesk.AutoCAD.Ribbon.RibbonServices.RibbonPaletteSet.RibbonControl;
And make sure all references are from ObjectARX folder with Copy Local equals FALSE.
Augusto Goncalves
Autodesk Developer Network
Member
winnes
Message 3 of 11 (363 Views)
06-18-2013 03:23 PM in reply to: augusto.goncalves
All references are already set to CopyLocal = False
Code is called by command (so after loading of all AutoCAD stuff, no?)
As far as I understand, Autodesk.AutoCAD.Ribbon.RibbonServices.RibbonPaletteSet.RibbonControl is an internal API (AcRibbon.dll), which I cannot reference?
Visual Studio Compiler tells me a property is used as a type...
All of a sudden, I am losing it :smileyhappy:
Also, you mention possible timing issue?
Wonder how (my environment ok, clients not?)
However, I found code that puts this kind of thing in OnIdle... mmm
augusto.goncalves
Message 4 of 11 (349 Views)
06-19-2013 06:52 AM in reply to: winnes
Don't loose it just yet :smileyhappy:
It should be under AcWindows.dll and AdWindows.dll references.
Are you using on the same version of AutoCAD?
About the timing, don't use OnIdle, but maybe something like
  public class AdskApplication : IExtensionApplication
    public void Initialize()
      if (Autodesk.Windows.ComponentManager.Ribbon == null)
        //load the custom Ribbon on startup, but at this point
        //the Ribbon control is not available, so register for
        //an event and wait
        Autodesk.Windows.ComponentManager.ItemInitialized +=
            new EventHandler<RibbonItemEventArgs>(ComponentManager_ItemInitialized);
      else
        //the assembly was loaded using NETLOAD, so the ribbon
        //is available and we just create the ribbon
        createRibbon();
    public void Terminate()
    void ComponentManager_ItemInitialized(object sender, RibbonItemEventArgs e)
      //now one Ribbon item is initialized, but the Ribbon control
      //may not be available yet, so check if before
      if (Autodesk.Windows.ComponentManager.Ribbon != null)
        //ok, create Ribbon
        createRibbon();
        //and remove the event handler
        Autodesk.Windows.ComponentManager.ItemInitialized -=
Augusto Goncalves
Member
winnes
Message 5 of 11 (334 Views)
06-21-2013 02:30 PM in reply to: augusto.goncalves
Have tried the Autodesk.AutoCAD.Ribbon.RibbonServices.RibbonPaletteSet.RibbonControl... No Exception, but nothing else happens? So the custom Ribbon does not show at all.
I catched both System.Exception and Autodesk.AutoCAD.Runtime.Exception, but that does not reveal anything.
Since I explicitly do a NETLOAD and then type my command, I am pretty sure it is no timing issue.
Am I right? However, Autodesk.Windows.ComponentManager.Ribbon remains null???
Any other ideas?
Distinguished Mentor
BlackBox_
Message 6 of 11 (328 Views)
06-21-2013 03:37 PM in reply to: winnes
I'd highly recommend that you instead hook the Application.Idle Event in Initialize(), and then in your Idle Event handler, unregister the Event handler first, and then add your component(s) to ComponentManager.
Cheers
"Potential has a shelf life." - Margaret Atwood
Autodesk Exchange Apps ~ Autoloader ~ AutoCAD Security
BlackBox_
Message 7 of 11 (326 Views)
06-21-2013 03:42 PM in reply to: BlackBox_
Cheers
For reference:
Add Custom RibbonTab at Startup
Member
winnes
Message 8 of 11 (285 Views)
07-01-2013 05:43 AM in reply to: winnes
This is very useful information, I keep it for further reference.
Nevertheless, the client works in Classic View and needs more than just buttons, so a Tool Palette is more appropriate.
That works from the very first time!
Thanks for all the help.
BlackBox_
Message 9 of 11 (275 Views)
07-01-2013 04:00 PM in reply to: winnes
That is kind of you to say, winnes; I'm happy to help.
It sounds like you've got the Tool Palette under control, but if you've ever been interested in going a bit above and beyond, you might consider adding a Windows Presentation Foundation (WPF) UserControl, as Kean demonstrates here:
Member
winnes
Message 10 of 11 (265 Views)
07-02-2013 12:46 AM in reply to: BlackBox_
Sometimes, one needs to go fast... like this time.
Therefore, further reference, like in a "next" project.
For Office automation tasks I am already a longtime believer of the Ribbon...
WPF on the other hand is fairly new to me...
But there again, Kean is one of THE references, and once again it will certainly serve in the next iteration of this, or another project.
I already have some ideas for future use.
Thanks for the link
You are not logged in.
Announcements
Need installation help?
Ask the Community
