.NET
Reversing a Boolean operation.
7 REPLIES 7
Message 1 of 8
junoj
736 Views, 7 Replies
I would like to reversing a Boolean operation if an error happens.
I have two solids that when I try to perform a Subtract Boolean Operation gives me an error. When the error happens I lose both solids. I would like to be able to reverse the subtraction in an event of an error so that I still have both solids.
Thank you in advance.
Dim Solid_1 as Solid3d = CreateSoldFromPl(plinePoints1)
Dim Solid_2 as Solid3d = CreateSoldFromPl(plinePoints1)
Try
    Solid_1.BooleanOperation(BooleanOperationType.BoolSubtract, Solid_2)
End Try
7 REPLIES 7
Message 2 of 8
fieldguy
in reply to: junoj
Have you tried "Catch"?  It looks as if you are not using a catch statement which is what it was designed for.
Message 3 of 8
_gile
in reply to: junoj
I do not konw anything about the 'CreateSoldFromPl' method, but it looks like you're substracting a solid to an indentical one (the same 'plinePoints1' argument for both 'Solid_1' and 'Solid_2').
Gilles Chanteau
GileCAD
GitHub
Message 4 of 8
junoj
in reply to: fieldguy
Hi Fieldguy,
Yes I have tried the Try Catch , but it just catches the error. The solids are consumed after the unsuccessful subtraction.
Message 5 of 8
junoj
in reply to: _gile
Gilles,
Sorry, i just had a typo. The CreateSoldFromPL is just a function that creates a solid from polyline.
Updated Code
Dim Solid_2 as Solid3d = CreateSoldFromPl(plinePoints2)
Try
End Try
Message 6 of 8
junoj
in reply to: junoj
Sorry, I should have posted the error that i get:
The Boolean operation on solids failed.
Modeling Operation Error:
System inconsistency processing edge coincidence.
Message 7 of 8
Hallex
in reply to: junoj
Citation
You should delete a smaller solid right after this line of code,
otherwise you leave a solid with degenerate geometry
(i.e. zero geometry) in the database and that could cause issues:
solid1.BooleanOperation(BooleanOperationType.BoolSubtract, solid2)
Add this line:
solid2.Erase()
tr.Commit() etc
Found this explanation in my code collection
Message 8 of 8
junoj
in reply to: Hallex
Thank you Fieldguy, Gilles and Hallex.
I must have had a brain freeze. I was able to reverse it by using a nested transaction. This was my first time using a nested transaction . . .
Thank you again.
-J
”Boost
