.NET
Retrieving the plugin path - C#
3 REPLIES 3
Fergobirck
1335 Views, 3 Replies
Hello everyone,
It's my first post in here. I did a little search for this question but didn't found anything.
I'm developing a plugin for Autocad using C#. In the same folder of the plugin DLL, I have subfolder (let's call it "data") that contains a lot of files that my plugin will use. In order to make the program work indepedent of the location of the DLL file (and the subfolder), I need to get the directory of my plugin dll. Anyone knows how can I achieve this? If this was a regular C# Winforms application, I would use "Application.StartupPath", but that's not available when developing an Autocad plugin.
Thanks in advance,
Fergo.
3 REPLIES 3
hgasty1001
in reply to: Fergobirck
This slould work: System.Reflection.Assembly.GetExecutingAssembly.Location
Gaston Nunez
dgorsman
in reply to: hgasty1001
You might also want to try a more traditional route of using the registry, so that the data can be located on a personal network drive, common read-only network location, or similar place where a DLL might not be appropriate.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Fergobirck
in reply to: dgorsman
Thank you both for the answer. Turns out the StreamReader accepts relative paths, so all I needed to do was ".\\folder\\". Kind regards, Fergo.
”Boost
