.NET
Retrieving the COM class error 80080005
4 REPLIES 4
1325 Views, 4 Replies
Hello all,
I´am having a problem in deploying an application developed in .net 2005 in a windows xp with the AutoCAD 2006 lt installed. I get the following error. Retrieving the COM class factory for component with CLSID {1365A45F-0C8F-4806-A26A-6B22AD37EC66} failed due to the following error:80080005.
I manage to understand that the some COM component is not registered in windows. How can I solve this? and how can i register the AutoCAD COM components(witch components?) in the system. My application was deployed using the One click install of the VB .net express edition.
Thank you for the help.
Best Regards,
André Cunha
4 REPLIES 4
Hi André
I have the exact same problem.
I have a develpment server where the error occur. Sometimes AutoCAD will launch other times it won't.
have you found a solution?
Regards
Peter
cadguru1
Same problem here.. For me it is with Acad mechanical 2008. Com class factory error 800800005 but the app works fine when I run it in debug mode!!
Any solution..??? Autodesk..listening??
Hello guys,
I know this post is old but I have the same problem. Did you find more information? How did you resolve this situation?
Your input is really appreciated.
Have a nice day!
Sebastien
sebastien (at) processia (.) com
I have the same issue on Vista using AutoCAD LT 2011. What was the solution?
”Boost
