.NET
Reset Documet status
4 REPLIES 4
327 Views, 4 Replies
I insert custom data into my document when it gets created. After this is complete, I want to reset the document so that if the user closes the document without doing anything else, they do not get prompted to save it.
It would also seem proper to flush any undo tracking on this data as well.
Seems that I saw a post about this, but can't seems to find it.
HomeBoy Out
4 REPLIES 4
arcticad
My two cents worth ...
You can check for the status
{code}
Dim isModified As Integer = System.Convert.ToInt32(Application.GetSystemVariable("DBMOD"))
Dim DOC As Document = Application.DocumentManager.MdiActiveDocument
If isModified = 0 Then
doc.CloseAndDiscard()
Else
doc.CloseAndSave(doc.Name)
End If
{code}
Then save and close based on it.
I know you can reset it using lisp.
(acad-push-dbmod)
; stuff
(acad-pop-dbmod)
I would be interested how to do this also.
(defun botsbuildbots() (botsbuildbots))
Shameless bump.....
Any Hints?
HomeBoy Out
Call these before/after your changes:
Document.PushDbMod()
Document.PopDbMod()
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6229554@discussion.autodesk.com...
Shameless bump.....
Any Hints?
HomeBoy Out
Thanks Tony
”Boost
