.NET
Require AcCoreMgd.dll 32-bit
4 REPLIES 4
2882 Views, 4 Replies
I have installed a 64-bit Autocad 2013 on my machine. Am building software which needs to work with both 32 and 64 bit Windows OS. Could someone please provide me a 32-bit dll of AcCoreMgd.dll. Though I don't package it, I need to reference it before my project compiles it right.
I tried downloading the entire installation, but it does it via an installer.The ObjectARX don't have it as well.
So, please oblige. Thanks.
Tags (1)
4 REPLIES 4
norman.yuan
What kind of software you are building? Something run inside AutoCAD only (AutoCAD add-ins), or something run as standalone aoolication outside AutoCAD (EXE, web/windows services...)?
If you do AutoCAD add-in with ObjectARX .NET API and you do not have to care about whether your AutoCAD .NET Add-in is written against 32-bit or 64-bit AutoCAD/OS (unless you uses something third party COM components or some Windows API). When you have AutoCAD isnatlled, be it 32 or 64-bit, you simply set reference to the correct accoremgd.dll, which your user already has it anyway.
If you application runs outside AutoCAD, you simply cannot use accoremgd.dll, period.
Also, what did you try to download? The ObjectARX SDK (Acad2013/2013) does include "accoremgd.dll" in the .\inc folder. You may or may not be aware that the managed DLL (acdbmgd.dll/acmgd.dll/accoremgd.dll) is for development only and they cannot be distributed to AutoCAD user to run your application - AutoCAD installation has them installed alreay, and the SDK version of these file will not run with AutoCAD.
Norman Yuan
Drive CAD With Code
in reply to: norman.yuan
Thanks for your time. My application uses Autocad dlls for running custom functions inside AutoCAD. In this case, it was referencing some types, and hence I needed the dlls without actually requiring the execution in Autocad.
I was able to locate the dlls inside the object ARX. Windows Search failed me, the previous time.
norman.yuan
... hence I needed the dlls without actually requiring the execution in Autocad.
That is NOT POSSIBLE.
The managed API DLLs (acdbmgd.dll/acmgd.dll/accoremgd.dll) can only be used insdie of AutoCAD, that is, AutoCAD MUST be executing/running.
Norman Yuan
Drive CAD With Code
arcticad
You can either use REALDWG to modify the dwg file externally without AutoCAD or use AutoCAD OEM distribute a custom CAD program
AutoCAD RealDWG
http://www.autodesk.com/realdwg
AutoCAD OEM
http://usa.autodesk.com/adsk/servlet/index?id=790640&siteID=123112
(defun botsbuildbots() (botsbuildbots))
”Boost
