.NET
Distinguished Contributor
vince1327
Message 11 of 36 (252 Views)
Re: Repeatedly Insert Block
01-24-2012 01:24 PM in reply to: cincir
Thanks a million, i've got it up and running so far, I really do appreciate everyone's help. I have just one last question that may be a bit unrealted, however here goes. When I create my new block reference and append it, it imports on the layer it was on in it's original DWG. How do i specify it to import onto a layer of my choosing. I've tried this already:
for (int i = 0; i < quantity; i++)
BlockReference bref = new BlockReference(pCenter, BlkId);
bref.Layer = "CH-SPR";
btr.AppendEntity(bref);
tr.AddNewlyCreatedDBObject(bref, true);
pCenter += vOffset;
bref.ExplodeToOwnerSpace();
bref.Erase();
catch
MessageBox.Show("Failed to read the DWG from the refence folder, are you sure it is present?");
finally
tr.Commit();
this.Close();
Thanks again
Vince
Active Contributor
cincir
Message 12 of 36 (250 Views)
01-24-2012 01:57 PM in reply to: vince1327
what is wrong with your code. it will work if there is a layer named like that. bu you have to set the attributereferences' layer to that only if they exist.if you want to assign LayerId property of the object you must first get your layertablerecord first like this
LayerTable acLayerTbl = acTrans.GetObject(acCurDB.LayerTableId,OpenMode.ForRead) as LayerTable;
ObjectId acLayerId = ObjectId.Null;
if (acLayerTbl.Has("SomeLayerName"))
    acLayerId = acLayerTbl["SomeLayerName"];
else
    LayerTableRecord acLayerTblRec = new LayerTableRecord();
    acLayerTblRec.Name = "SomeLayerName";
    acLayerTbl.UpgradeOpen();
    acLayerId = acLayerTbl.Add(acLyerTblRec);
    acTrans.AddNewlyCreatedObject(acLayerTblRec,true);
acBlkRef.LayerId = acLayerId;
 use this aproach if you want to check if there is the layer you want to assign and create if not.
vince1327
Message 13 of 36 (233 Views)
01-25-2012 05:58 AM in reply to: cincir
Hey Cincir,
I've actually create the layer beforehand and can verify that it exists...the code looks like below. I'm not sure why it won't import onto the CH-SPR layer though, this has been one of those small things on my list for weeks now and it's driving me mad.
Transaction tr = doc.TransactionManager.StartTransaction();
using (DocumentLock acLckDoc = doc.LockDocument())
try
//Check to see if the layer CH-SPR already exists, if so use it, if not create it and then use it
string sLayerName1 = "CH-SPR";
LayerTable acLyrTbl1; acLyrTbl1 = tr.GetObject(db.LayerTableId, OpenMode.ForRead) as LayerTable;
LayerTableRecord acLyrTblRec;
if (acLyrTbl1.Has(sLayerName1) == false)
acLyrTblRec = new LayerTableRecord();
// Assign the layer a name
acLyrTblRec.Name = sLayerName1;
// Upgrade the Layer table for write
if (acLyrTbl1.IsWriteEnabled == false) acLyrTbl1.UpgradeOpen();
// Append the new layer to the Layer table and the transaction
acLyrTbl1.Add(acLyrTblRec);
tr.AddNewlyCreatedDBObject(acLyrTblRec, true);
else
// Open the layer if it already exists for write
acLyrTblRec = tr.GetObject(acLyrTbl1[sLayerName1], OpenMode.ForWrite) as LayerTableRecord;
//This function will import the selected dwg into modelspace and activate it
if (comboBox1.Text == "FACSPR7")
comp = "C:\\ACADSTUFF\\FACSPR7.dwg";
if (comboBox1.Text == "FACSPR1")
comp = "C:\\ACADSTUFF\\FACSPR1.dwg";
if (comboBox1.Text == "FACSPR17")
comp = "C:\\ACADSTUFF\\FACSPR17.dwg";
if (comboBox1.Text == "FACSPR22")
comp = "C:\\ACADSTUFF\\FACSPR22.dwg";
if (comboBox1.Text == "FACSPR31")
comp = "C:\\ACADSTUFF\\FACSPR31.dwg";
string dwgName = HostApplicationServices.Current.FindFile(comp, acadApp.DocumentManager.MdiActiveDocument.Database, FindFileHint.Default);
Database db1 = new Database(false, false);
db1.ReadDwgFile(dwgName, System.IO.FileShare.Read, true, "");
ObjectId BlkId;
BlkId = doc.Database.Insert(dwgName, db1, false);
BlockTable bt = (BlockTable)tr.GetObject(doc.Database.BlockTableId, OpenMode.ForRead, true);
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
int quantity = Convert.ToInt32(numericUpDown1.Value);
Point3d pCenter = new Point3d(0, 0, 0);
Vector3d vOffset = new Vector3d(1000, 0, 0);
pCenter += vOffset;
bref.Erase();
catch
finally
tr.Commit();
this.Close();
private void numericUpDown1_ValueChanged(object sender, EventArgs e)
private void pictureBox1_Click(object sender, EventArgs e)
Active Contributor
cincir
Message 14 of 36 (231 Views)
01-25-2012 06:18 AM in reply to: vince1327
vince1327 you are assigning layer to the blockref then erase it after exploding so the individual entities' layers that comprise the block definition must be set in order to accomplish this task. Do you have to explode them?
vince1327
Message 15 of 36 (228 Views)
01-25-2012 06:33 AM in reply to: cincir
Hey Cincir,
The reason that i'm exploding them to ownerspace is because that is the only way that I can get them to show up on the actual drawing. Is there another way?
Cheers
Active Contributor
cincir
Message 16 of 36 (224 Views)
01-25-2012 07:02 AM in reply to: vince1327
comment the explodetomodelspce and erase lines and see what will you get :smileyhappy:
vince1327
Message 17 of 36 (221 Views)
01-25-2012 07:22 AM in reply to: cincir
Cool, so that brough it in as a block reference on the correct layer. The problem though is that I need all the attributes that it would normally have if it was exploded...So right now i'm stuck at crossroads...I can have it brought in and explode it, but it's in the wrong layer...or I could bring it into the correct layer as a block reference but not have any of my attributes...is there a middle ground somewhere. Can i explode it and then transfer it to the correct layer?
Thanks so much!
Active Contributor
cincir
Message 18 of 36 (218 Views)
01-25-2012 07:39 AM in reply to: vince1327
you are at the wrong tides. your blockreference can have all the attributedefinitions as your blockdefinition as attributereference. :smileywink:
vince1327
Message 19 of 36 (216 Views)
01-25-2012 07:42 AM in reply to: cincir
hey cincir, i'm not sure what you mean by this...sorry i'm actually very new to this and sometimes the terminology along with the api are very confusing. How do i implement the attributereference that you're talking about?
Active Contributor
cincir
Message 20 of 36 (211 Views)
01-25-2012 08:09 AM in reply to: vince1327
BlockTableRecord acBlkDef = acTrans.GetObject(BlkId,OpenMode.ForRead) as BlockTableRecord;
   if (acBlkDef.HasAttributeDefinitions)
      foreach(ObjectId acAttId in acBlkDef)
         Entity acTempEnt = (Entity)acTrans.GetObject(acAttId,OpenMode.ForRead);
         if (acTempEnt is AttributeDefinition)
             AttributeReference acAttRef = new AttributeReference();
              acAttRef.SetAttributeFromBlock((AttributeDefinition)acTempEnt,bref.BlockTransform);
             acAttRef.Layer = "CH-SPR";
             bref.AttributeCollection.AppendAttribute(acAttRef);
             acTrans.AddNewlyCreatedDBObject(acAttRef,true);
   pCenter += vOffset;
 it is hard to write code without Visual Studio Intellisence :smileyhappy:
You are not logged in.
Ask the Community
