- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hey everyone,
So i've been able to successfully import a single block at a time into an active drawing, now i'm trying to insert the same block multiple times to essentially create a layout within the drawing. How would i go about inserting a selected block "x" amount of times. For a better idea of where i'm stuck, i've commented a bit of code below with a better explanation. What i've got so far is this:
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.DataExtraction;
using Autodesk.AutoCAD.Colors;
using DB_Extraction;
using acadApp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace CHTEST
public class CHTEST1
// This is the name of my command
[Autodesk.AutoCAD.Runtime.CommandMethod("CHTEST")]
public void CHTEST1()
Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
Point3d pMax = new Point3d();
string comp = "C:\\ACADSTUFF\\test.dwg";
// int numsprink = 5;
Transaction tr = doc.TransactionManager.StartTransaction();
using (DocumentLock acLckDoc = doc.LockDocument())
try
//Check to see if the layer CH-TST already exists, if so use it, if not create it and then use it
string sLayerName1 = "CH-TST";
LayerTable acLyrTbl1; acLyrTbl1 = tr.GetObject(db.LayerTableId, OpenMode.ForRead) as LayerTable;
LayerTableRecord acLyrTblRec;
if (acLyrTbl1.Has(sLayerName1) == false)
acLyrTblRec = new LayerTableRecord();
// Assign the layer a name
acLyrTblRec.Name = sLayerName1;
// Upgrade the Layer table for write
if (acLyrTbl1.IsWriteEnabled == false) acLyrTbl1.UpgradeOpen();
// Append the new layer to the Layer table and the transaction
acLyrTbl1.Add(acLyrTblRec);
tr.AddNewlyCreatedDBObject(acLyrTblRec, true);
else
// Open the layer if it already exists for write
acLyrTblRec = tr.GetObject(acLyrTbl1[sLayerName1], OpenMode.ForWrite) as LayerTableRecord;
//This partwill import the selected dwg into modelspace and activate it
string dwgName = HostApplicationServices.Current.FindFile(comp, acadApp.DocumentManager.MdiActiveDocument.Database, FindFileHint.Default);
Database db1 = new Database(false, false);
db1.ReadDwgFile(dwgName, System.IO.FileShare.Read, true, "");
ObjectId BlkId;
BlkId = doc.Database.Insert(dwgName, db1, false);
BlockTable bt = (BlockTable)tr.GetObject(doc.Database.BlockTableId, OpenMode.ForRead, true);
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
//ideally this next section will iterate the import process "x" amount of times and allow for effetive block placement!
// Below is part of some code that i had used to copy a paperspace layout "x" amount of times. I understand the iteration part but am not sure how to apply it to a block. I don't know how to reference the block that i intend to insert and then have it populate "x" amount of times.
for (int i = 1; i <= numLayouts; i++)
lm.CopyLayout("Layout1", "SP-" + i.ToString());
Layout layout = (Layout)trx.GetObject(lm.GetLayoutId("SP-" + i.ToString()), OpenMode.ForWrite);
//FACSPR7
BlockReference bref = new BlockReference(pMax, BlkId);
bref.Layer = "CH-TST";
btr.AppendEntity(bref);
tr.AddNewlyCreatedDBObject(bref, true);
bref.ExplodeToOwnerSpace();
bref.Erase();
tr.Commit();
catch
MessageBox.Show("Failed to read the DWG from the refence folder, are you sure it is present?");
finally
tr.Dispose();
