.NET
Rename layer with vb.net
5 REPLIES 5
DerUhrmacher
1524 Views, 5 Replies
Hello
I tried to rename layers this way, but it seems not to work.
What is wrong with it? No errormessage, but no result too 😞
Andreas
Private Sub LayerRename(ByVal OldName As String, ByVal NewName As String)
Dim myDWG As ApplicationServices.Document
Dim myTransMan As DatabaseServices.TransactionManager
Dim myTrans As DatabaseServices.Transaction
myDWG = ApplicationServices.Application.DocumentManager.MdiActiveDocument
myTransMan = myDWG.TransactionManager
myTrans = myTransMan.StartTransaction
Dim myLT As DatabaseServices.LayerTable
Dim myLTR As DatabaseServices.LayerTableRecord
Dim mySTE As DatabaseServices.SymbolTableEnumerator
myLT = myDWG.Database.LayerTableId.GetObject(DatabaseServices.OpenMode.ForRead)
mySTE = myLT.GetEnumerator
While mySTE.MoveNext
myLTR = mySTE.Current.GetObject(DatabaseServices.OpenMode.ForRead)
If myLTR.Name = OldName Then
myLTR.UpgradeOpen()
myLTR.Name = NewName
End While
myTrans.Dispose()
myTransMan.Dispose()
End Sub
5 REPLIES 5
in reply to: DerUhrmacher
Hi Andreas,
Try committing your transaction.
I would also import ApplicationServices and DatabaseServices.
James Allen
Malicoat-Winslow Engineers, P.C.
Columbia, MO
as@uhrteil.ch wrote:
> Hello
> Regards,
> Andreas
> myLTR.UpgradeOpen()
> End If
> End While
> myTrans.Dispose()
> End Sub
DerUhrmacher
Hello James
Thank You very much.
Sometimes after nights at the computer, You don't see the simpliest things 🙂
I placed the "myTrans.Commit()" just in the line before "end if" and now it works.
Kind regards
Andreas
Check out using a Using statemtment to dispose of your underlying unmanaged
Objects.
Also For Each to enumerate your SymbolTable...
{code}
Public Sub Cmd1() ' This method can have any name
Dim doc As Document = _
Using tr As Transaction = _
doc.Database.TransactionManager.StartTransaction()
Dim layTable As LayerTable = _
tr.GetObject(doc.Database.LayerTableId, _
OpenMode.ForRead)
Dim id As ObjectId
For Each id In layTable
Dim rec As LayerTableRecord = _
tr.GetObject(id, OpenMode.ForRead)
If (rec.Name = "gunga") Then
rec.UpgradeOpen()
rec.Name = "lagunga"
Next
tr.Commit()
End Using
'or better...
doc.TransactionManager.StartTransaction()
OpenMode.ForRead)
If (layTable.Has("goo")) Then
Dim r As LayerTableRecord = _
tr.GetObject(layTable("goo"), OpenMode.ForWrite)
r.Name = "bar"
tr.Commit()
End Using
End Sub
{code}
wrote in message news:6211936@discussion.autodesk.com...
Hello
Andreas
myDWG =
myLT =
myLTR =
myLTR.UpgradeOpen()
End While
myTrans.Dispose()
End Sub
I should have stuck and Exit For in the loop...
{code}
rec.UpgradeOpen()
Exit For
{code}
"Paul Richardson" wrote in message
news:6212318@discussion.autodesk.com...
Objects.
{code}
OpenMode.ForRead)
Dim id As ObjectId
rec.UpgradeOpen()
Next
tr.Commit()
End Using
'or better...
OpenMode.ForRead)
r.Name = "bar"
tr.Commit()
End Using
End Sub
{code}
Hello
Andreas
myDWG =
myLT =
myLTR =
myLTR.UpgradeOpen()
End While
myTrans.Dispose()
End Sub
You're welcome.
James
DerUhrmacher wrote:
> Hello James
> Kind regards
> Andreas
”Boost
