Hi.
I've got a problem using remoting with AutoCAD.
I want to implement a kind of server in AutoCAD that enables external processes to get access to AutoCAD functions.
I have a VS-solution with this layout:
AutoCADServer (dll, class implements IExtensibleApplication)
AutoCADWorker (dll, derived from MarshalByObjReg)
Client1 (exe)
I want to implement certain functionality in AutoCADWorker, like opening DWGs, plotting, some other stuff...
The user now starts Client1 and is able to use this functionality exposed by AutoCADWorker.
At least, this is the idea.
To do this, I have this code:
public class AutoCADServer : IExtensionApplication
public void Initialize()
RemotingConfiguration.Configure(path_to_server_config, false);
// Snip some other unrelated stuff
public class AutoCADWorker : MarshalByRefObject
public void DoSomething()
// does something nice in AutoCAD
public partial class Form1 : Form
RemotingConfiguration.Configure(path_to_client_config, false);
AutoCADWorker.AutoCADWorker remoteObject = (AutoCADWorker.AutoCADWorker)Activator.GetObject(typeof(AutoCADWorker.AutoCADWorker), "tcp://localhost:8989/AutoCADServer");
remoteObject.DoSomething();
The config files look like this (< replaced by [):
server_config:
[configuration]
[system.runtime.remoting]
[application]
[service]
[wellknown
mode="Singleton"
type="AutoCADWorker.AutoCADWorker, AutoCADWorker"
objectUri="AutoCADServer"
[/service]
[channels]
[channel ref="tcp" port="8989"/]
[/channels]
[/application]
[/system.runtime.remoting]
[/configuration]
client_config:
[configuration]
[application]
[client]
[wellknown
url="tcp://localhost:8989/AutoCADServer"
[/client]
[/application]
[/configuration]
Now when I try to load the plugin in AutoCAD, calling RemotingConfiguration.Configure raises an exception, complaining about already having registered a channel named "tcp".
Using Process Explorer, I figured that AutoCAD already opens some .NET channels, appearently, there's really another one named "tcp".
My problem is I don't know how I should give the channel a different name, as there's only an attribute "displayName" for the channel-tag in the config,
but according to MS documentation this isn't used by applications but only to display the name in .NET config tools.
Has anyone done this or something similar before and could help me with this?
I need to get this working soon, I already spend some days with this stuff...
Best Regards
Christian Nitschkowski
