.NET
Valued Contributor
dhimant.bhensdadia
Message 1 of 5 (236 Views)
Reg. Could Not Load Acdbmgd.dll
236 Views, 4 Replies
10-31-2013 04:02 AM
I have made the insertblock.dll (Class Library Project) file to insert the block in one of my drawing file.
For this, I have to Open the drawing file and using NETLOAD command to load my insertblock.dll and inserting block. It is working fine.
Now I have made the Windows Project (EXE project) and in that I  have added my insertblock.dll and executing the EXE file and calling the InsertBlock funtion that inside in insertblock.dll file.
So in this case it is giving the error as shown in the attached Snapshot
Valued Contributor
sszabo
Message 2 of 5 (222 Views)
Re: Reg. Could Not Load Acdbmgd.dll
10-31-2013 05:31 AM in reply to: dhimant.bhensdadia
You can only reference *mgd*.dll from a plugin.  If you want to control autocad from an outside exe you have 2 options: COM interop assemblies or WCF.  There are articles on both.  I posted one here:
http://forums.autodesk.com/t5/NET/Catastrophic-failure-HRESULT-0x8000FFFF-E-UNEXPECTED/m-p/3765575#M...
Valued Contributor
dhimant.bhensdadia
Message 3 of 5 (216 Views)
10-31-2013 05:56 AM in reply to: dhimant.bhensdadia
Can you liitle bit ellaborate more so I can easily understand.
Means what chages need to be done in My EXE project to load my insertblock.dll file ?
norman.yuan
Message 4 of 5 (207 Views)
10-31-2013 06:18 AM in reply to: dhimant.bhensdadia
It means that you CANNOT use managed API DLLs from AutoCAD (acmgd.dll/acdbmgd.dll...) in EXE project. They can only be used in code that runs inside AutoCAD.
Valued Contributor
dhimant.bhensdadia
Message 5 of 5 (202 Views)
10-31-2013 06:21 AM in reply to: norman.yuan
OK...Thanks....
You are not logged in.
Ask the Community
