.NET
Reg. AutoCAD 2005 DLL Files
5 REPLIES 5
dhimant.bhensdadia
478 Views, 5 Replies
I have created one project in C#.NET using .NET API of AutoCAD 2013.
Now I want to do same in AutoCAD 2005, but the problem is there are only 2 dll files in AutoCAD 2005 named
1. acdbmgd.dll
2. acmgd.dll
For some of the functionality I also need accoremgd.dll, but I am not able to find the same in AutoCAD 2005 installer folder.
So in AutoCAD 2005, Another dll file is there that work similar to accoremgd.dll ?
or its not possible to in AutoCAD 2005 to access the functionality of accoremgd.dll ?
5 REPLIES 5
_gile
in reply to: dhimant.bhensdadia
AcCoreMgd.dll came with AutoCAD 2013 (with the split of acad.exe into acad.exe and accore.dll) and is not available with previous versions.
Gilles Chanteau
GileCAD
GitHub
dhimant.bhensdadia
in reply to: _gile
Thanks...Can you please tell me how can I migrate AutoCAD 2013 code into AutoCAD 2005 ?
bcs AutoCAD 2005 has 2 dll as mentioned above so how can I use the functionality of accoremgd.dll in AutoCAD 2005?
_gile
What functionalities are you talking about ?
Gilles Chanteau
GileCAD
GitHub
dhimant.bhensdadia
in reply to: _gile
In AutoCAD 2013
using Autodesk.AutoCAD.EditorInput; is there but in AutoCAD 2005
it is giving the error...
so any functionality that resides on EditorInput will not be worked in AutoCAD 2005 ?
Is there any workaround how can I use these functionality in 2005 ?
_gile
I do not know much about the A2005 .NET API (in my opinion, AutoCAD .NET API became truely usable with AutoCAD 2007 and the Framework 2.0).
Anyway you can browse the AcDbMgd.dll and AcMgd.dll in the Object Browser of Visual Studio.
Gilles Chanteau
GileCAD
GitHub
”Boost
