.NET
lukasz.taraszka
Message 1 of 3 (622 Views)
Refresh drawing when modal form is running
622 Views, 2 Replies
01-03-2012 12:52 AM
Hello everyone
Is it possible to refresh drawing content when modal form is running?
I placed sample project in attachment.
There is simple form with only one button.
Private Sub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click
        Class1.DrawLineOnScreen()
    End Sub
After button is pressed, application prompting user for picking 2 points, and draw a line (based on picked points).
Public Shared Sub DrawLineOnScreen()
        Dim editor As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        Dim pFirst As PromptPointOptions = New PromptPointOptions("First point: ")
        Dim rFirst As PromptPointResult = editor.GetPoint(pFirst)
        Dim pSecond As PromptPointOptions = New PromptPointOptions("Second point: ")
        Dim rSecond As PromptPointResult = editor.GetPoint(pSecond)
        If rFirst.Status = PromptStatus.OK AndAlso rSecond.Status = PromptStatus.OK Then
            Dim line As Line = New Line(rFirst.Value, rSecond.Value)
            Dim tr As Transaction =                Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction
            Using tr
                Dim modelSpace As BlockTableRecord = tr.GetObject(Application.DocumentManager.MdiActiveDocument.Database.CurrentSpaceId, OpenMode.ForWrite)
                modelSpace.AppendEntity(line)
                tr.AddNewlyCreatedDBObject(line, True)
                tr.Commit()
            End Using
        End If
    End Sub
Problem is that line had been added to transaction (to Model Space block table record) but nothing change on a drawing. Line will appear on a drawing after closing the form.
In opposite situation, without using modal form (only console) everyting works fine.
<CommandMethod("DrawLine", CommandFlags.Modal)> _
        Public Sub DrawLine()
        End Sub
SENL1362
Message 2 of 3 (616 Views)
Re: Refresh drawing when modal form is running
01-03-2012 03:12 AM in reply to: lukasz.taraszka
did you tried editor.Regen()
c# sample:
       private void Select_Click(object sender, EventArgs e)
            Document doc = Acad.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            using (EditorUserInteraction preventFlikkering = ed.StartUserInteraction(this))
                PromptPointOptions getPntPrmpt = new PromptPointOptions("\nGet Center");
                //Modal Form: will hide because of ed.GetPoint
                PromptPointResult getPnt = ed.GetPoint(getPntPrmpt);
                ed.WriteMessage("\nPoint: {0}", getPnt.Value);
                ed.Regen();
                preventFlikkering.End();
lukasz.taraszka
Message 3 of 3 (610 Views)
01-03-2012 03:55 AM in reply to: SENL1362
No, I have no idea about this method. I tried UpdateScreen but it didn't work.
Your post resolved my problem.
Thank You very much.
