• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Distinguished Contributor
    VB_Autocad_guy
    Accepted Solution
    Refine Block Definition with New Block
    383 Views, 8 Replies
    05-14-2012 12:18 PM
    How do I redefine a block...
    I want to insert the new block definition in the place of the old one and overwrite it.
    The new block has more attributes than the older instance.
    What a good method of going about that?
    Please use plain text.
    *Expert Elite*
    Hallex
    Re: Refine Block Definition with New Block
    05-14-2012 01:20 PM in reply to: VB_Autocad_guy
    Not sure about if this helps, this one is  similar on your task
       <CommandMethod("BlockReplaceTest", "breplace", CommandFlags.Session Or CommandFlags.Modal Or CommandFlags.UsePickSet Or CommandFlags.Redraw)> _
            Public Sub TestBlockReplaceByName()
                ' objects initializing
                Dim doc As Document = acApp.DocumentManager.MdiActiveDocument
                Dim ed As Editor = doc.Editor
                Dim db As Database = doc.Database
                Try
                    Using doc.LockDocument()
                        Using tr As Transaction = db.TransactionManager.StartTransaction()
                            Dim psto As New PromptStringOptions(vbLf & "Enter a replacement block name: ")
                            psto.AllowSpaces = True
                            psto.DefaultValue = "MyBlock"  'old block
                            Dim stres As PromptResult
                            stres = ed.GetString(psto)
                            If stres.Status <> PromptStatus.OK Then
                                Return
                            Dim oldblock As String = stres.StringResult
                            ed.WriteMessage(vbLf & "Text Entered" & vbTab & "{0}", oldblock)
                            psto = New PromptStringOptions(vbLf & "Enter a block name to be replaced: ")
                            psto.DefaultValue = "NewBlock"    'new block
                                Return
                            Dim newblock As String = stres.StringResult
                            Dim bt As BlockTable = TryCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
                            If Not bt.Has(newblock) Then
                                Return
                            Dim newblkId As ObjectId = bt(newblock)
                            acApp.SetSystemVariable("nomutt", 1)
                            Dim tvs As TypedValue() = {New TypedValue(0, "insert"), New TypedValue(2, oldblock)}
                            Dim filt As New SelectionFilter(tvs)
                            Dim pso As New PromptSelectionOptions()
                            pso.MessageForRemoval = "You must select the blocks only"
                            pso.MessageForAdding = vbLf & "Select replacement blocks: "
                            AddHandler ed.SelectionAdded, AddressOf ed_SelectionAdded
                            Dim res As PromptSelectionResult = ed.GetSelection(pso, filt)
                            If res.Status <> PromptStatus.OK Then
                                Return
                            Dim btr As BlockTableRecord = TryCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                            Dim sset As SelectionSet = res.Value
                            For Each obj As SelectedObject In sset
                                Dim ent As Entity = TryCast(DirectCast(obj.ObjectId.GetObject(OpenMode.ForRead), Entity), Entity)
                                Dim oldblk As BlockReference = TryCast(ent, BlockReference)
                                Dim ip As Point3d = oldblk.Position
                                Dim scl As Scale3d = oldblk.ScaleFactors
                                Dim rot As Double = oldblk.Rotation
                                Dim newblk As New BlockReference(ip, newblkId)
                                newblk.SetPropertiesFrom(ent)
                                newblk.Rotation = rot
                                newblk.ScaleFactors = scl
                                btr.AppendEntity(newblk)
                                tr.AddNewlyCreatedDBObject(newblk, True)
                                ApplyAttributes(db, tr, newblk)
                                oldblk.UpgradeOpen()
                                oldblk.Erase()
                                oldblk.Dispose()
                            Next
                            tr.Commit()
                        End Using
                    End Using
                Catch ex As System.Exception
                    ed.WriteMessage(ex.Message & vbLf & ex.StackTrace)
                Finally
                    acApp.SetSystemVariable("nomutt", 0)
                    RemoveHandler ed.SelectionAdded, AddressOf ed_SelectionAdded
                End Try
            End Sub
            Private Sub ed_SelectionAdded(sender As Object, e As SelectionAddedEventArgs)
                ' you may want to add some action here
                DirectCast(sender, Editor).WriteMessage(vbLf & vbTab & "{0} blocks to selection added", e.AddedObjects.Count)
            End Sub
            Public Sub ApplyAttributes(db As Database, tr As Transaction, bref As BlockReference)
                Dim btrec As BlockTableRecord = TryCast(tr.GetObject(bref.BlockTableRecord, OpenMode.ForRead), BlockTableRecord)
                If btrec.HasAttributeDefinitions Then
                    Dim atcoll As Autodesk.AutoCAD.DatabaseServices.AttributeCollection = bref.AttributeCollection
                    For Each subid As ObjectId In btrec
                        Dim ent As Entity = DirectCast(subid.GetObject(OpenMode.ForRead), Entity)
                        Dim attDef As AttributeDefinition = TryCast(ent, AttributeDefinition)
                        If attDef IsNot Nothing Then
                            Dim attRef As New AttributeReference()
                            attRef.SetDatabaseDefaults()
                            'optional
                            attRef.SetAttributeFromBlock(attDef, bref.BlockTransform)
                            attRef.Position = attDef.Position.TransformBy(bref.BlockTransform)
                            attRef.Justify = attDef.Justify
                            'must be added all other properties for right position, eg. alignment modes etc
                            attRef.Tag = attDef.Tag
                            attRef.AdjustAlignment(db)
                            atcoll.AppendAttribute(attRef)
                            tr.AddNewlyCreatedDBObject(attRef, True)
                    Next
            End Sub
    ~'J'~
    _____________________________________
    C6309D9E0751D165D0934D0621DFF27919
    Moderator
    Alexander.Rivilis
    05-14-2012 01:22 PM in reply to: VB_Autocad_guy
    That post and comments can be good start for you: http://adndevblog.typepad.com/autocad/2012/05/redefining-a-block.html
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
    *Expert Elite*
    chiefbraincloud
    05-14-2012 03:06 PM in reply to: VB_Autocad_guy
    The post link Alexander provided is a good start, but does not address the issue of adding or subtracting attributes.  After using the method Stephen Prestons code, you would also need to open each BlockReference (could be in the same loop where he calls RecordGraphicsModified) and add or remove AttributeReferences from it based on the AttributeDefinitions found in the BlockTableRecord.
    VB_Autocad_guy
    05-14-2012 03:46 PM in reply to: chiefbraincloud
    Thanks Chiefbraincloud, and everyone else... this will definetly get me started in the process.
    Just trying to get an idea of the basic workflow.
    The add attribute reference... okay I remember that. Used that one before somewhere.
    Thanks again!
    VB_Autocad_guy
    05-15-2012 08:39 AM in reply to: VB_Autocad_guy
    So I'm getting the error eSelfReference....
    I already have a different definintion of the block Test in my drawing.
    What I'm wanting to do is overwrite this version in the current drawing with the one c:\temp\test.dwg as my new blockdefinition.
      <Autodesk.AutoCAD.Runtime.CommandMethod("ReplaceBlock")> _
        Public Sub ReplaceBlock()
            Dim myDwg As Document = Application.DocumentManager.MdiActiveDocument
            Dim myDB As Database = myDwg.Database
            Dim blockName As String = "TEST"
            Editor.WriteMessage("Replacing Block" & Environment.NewLine)
            Dim BlkDB As Database = New Database(False, True)
            BlkDB.ReadDwgFile("C:\\Temp\\TEST.dwg", System.IO.FileShare.Read, True, "")
            Using myTrans As Transaction = myDB.TransactionManager.StartTransaction()
                Dim blockTable As BlockTable = myTrans.GetObject(myDB.BlockTableId, OpenMode.ForRead, False, True)
                Dim myBlockDefId As ObjectId = myDB.Insert(blockName, BlkDB, True)
                If myBlockDefId <> ObjectId.Null Then
                    Dim myBlockDef As BlockTableRecord = myTrans.GetObject(myBlockDefId, OpenMode.ForRead, False, True)
                    Dim myBlockRefIds As ObjectIdCollection = myBlockDef.GetBlockReferenceIds(False, True)
                    For Each id As ObjectId In myBlockRefIds
                        Dim myBlockRef As BlockReference = myTrans.GetObject(id, OpenMode.ForWrite, False, True)
                        myBlockRef.RecordGraphicsModified(True)
                        'Append Attribute References to the BlockReference
                        Dim myAttColl As DatabaseServices.AttributeCollection
                        Dim myEntID As ObjectId
                        Dim myEnt As DatabaseServices.Entity
                        myAttColl = myBlockRef.AttributeCollection
                        For Each myEntID In myBlockDef
                            myEnt = myEntID.GetObject(OpenMode.ForWrite)
                            If TypeOf myEnt Is DatabaseServices.AttributeDefinition Then
                                Dim myAttDef As DatabaseServices.AttributeDefinition = _
                               CType(myEnt, AttributeDefinition)
                                Dim myAttRef As New DatabaseServices.AttributeReference
                                myAttRef.SetAttributeFromBlock(myAttDef, myBlockRef.BlockTransform)
                                myAttColl.AppendAttribute(myAttRef)
                                myTrans.AddNewlyCreatedDBObject(myAttRef, True)
                        Next
                    Next
                myTrans.Commit()
            End Using
            BlkDB.Dispose()
        End Sub
    VB_Autocad_guy
    05-15-2012 08:51 AM in reply to: VB_Autocad_guy
    The other problem is it's Adding Duplicate Attribute Definitions.
                                Dim myAttDef As DatabaseServices.AttributeDefinition = CType(myEnt, AttributeDefinition)
                            End
    Hmm... I need to test if the attribute already exists, and either overwrite it, or delete the old one, and re-create it.
    *Expert Elite*
    chiefbraincloud
    05-15-2012 08:57 AM in reply to: VB_Autocad_guy
    I didn't try out your code, and I do see one problem, where you'll need to check if an attribute exists before...
    I see you noticed that already.
    I'm guessing that your c:\temp\test.dwg has a block defined in it named test.  That is what I would expect to find if I got an eSelfReference exception.
    Open your test.dwg and run the insert command.  See if there is a "test" block in the list, and if so, purge it, and save, then try your code again.
    VB_Autocad_guy
    05-15-2012 10:08 AM in reply to: chiefbraincloud
    Yah. I purged the block out of the drawing. Now that part is working.
    Just trying to figure out the part if an attribute exists already.
    Thanks for the help!
    :smileyhappy:
