Hello Forum,
I use the following code to redefine a block:
objBlockTable = (BlockTable)objTransactionManager.GetObject(objDatabaseSource.BlockTableId, OpenMode.ForRead, false);
structObjectId = objBlockTable[strBlockName];
objBlockTableRecord = (BlockTableRecord)objTransactionManager.GetObject(structObjectId, OpenMode.ForRead, false);
objObjectIdCollection.Add(structObjectId);
objIdMapping = new IdMapping();
objDatabaseSource.WblockCloneObjects(objObjectIdCollection, objDatabase.BlockTableId, objIdMapping, DuplicateRecordCloning.Replace, false);
It works for normal blocks but it does not redefine dymanic blocks. Is there a way to redefine dynamic blocks?
Thank you.
Hello again,
I've come up with the following code for redefining dynamic blocks:
- Redefine dynamic block (not in code).
- Store dynamic property values of each block reference.
- Reset each block reference to 'apply' the newly redefined block.
- Set the stored dynamic property values.
* Calling ResetBlock and Setting dynamic property values in a single transaction results in strange behavior, so multiple transactions are required.
If anyone knows a better/more efficient way, please let me know. Thank you,
Test code:
[CommandMethod("AnalyzeDyn", CommandFlags.Session)] public void AnalyzeDyn() { Document objDocument; Database objDatabase; DocumentLock objDocumentLock; Transaction objTransaction; BlockTable objBlockTable; BlockTableRecord objBlockTableRecord; string strMsg = ""; BlockReference objBlockReference; Dictionary<string, object> objDictionary = new Dictionary<string, object>(); List<ObjectId> oidList = new List<ObjectId>(); double dblValue; try { objDocument = CADS.Application.DocumentManager.MdiActiveDocument; objDatabase = objDocument.Database; using (objDocumentLock = objDocument.LockDocument()) { using (objTransaction = objDocument.TransactionManager.StartTransaction()) { // Get the blocktable of the database. objBlockTable = objTransaction.GetObject(objDatabase.BlockTableId, OpenMode.ForRead) as BlockTable; // 1: Add all blocktablerecord id's to a list. // Then loop this list. // You can't loop 'objBlockTable' directly because it will be altered inside the loop. // (I think by 'ResetBlock') That will result in an endless loop. // Reset will create a new anonymous block. // 2: Calling 'ResetBlock' and editing dynamic properties in the same transaction causes strange results. oidList.Clear(); foreach (ObjectId oidBlockTableRecord in objBlockTable) { oidList.Add(oidBlockTableRecord); } } // Get each ObjectID in the blocktable. foreach (ObjectId oidBlockTableRecord in oidList) { // Check if the ObjectID is anonymous. using (objTransaction = objDocument.TransactionManager.StartTransaction()) { objBlockTableRecord = objTransaction.GetObject(oidBlockTableRecord, OpenMode.ForRead) as BlockTableRecord; } if (objBlockTableRecord.IsAnonymous) { // Get all block references. foreach (ObjectId oidBlockReference in objBlockTableRecord.GetBlockReferenceIds(false, false)) { objDictionary.Clear(); if (strMsg.Length > 0) { strMsg += System.Environment.NewLine; } using (objTransaction = objDocument.TransactionManager.StartTransaction()) { objBlockReference = objTransaction.GetObject(oidBlockReference, OpenMode.ForWrite) as BlockReference; // Get all properties. foreach (DynamicBlockReferenceProperty objItem in objBlockReference.DynamicBlockReferencePropertyCollection) { strMsg += objItem.PropertyName.ToString(); strMsg += " = " + objItem.Value.ToString(); strMsg += " (" + objItem.Value.GetType().ToString() + ")."; // Only add items that are not readonly. if (!objItem.ReadOnly && !objDictionary.ContainsKey(objItem.PropertyName)) { objDictionary.Add(objItem.PropertyName, objItem.Value); } } // Reset. objBlockReference.ResetBlock(); // Commit. objTransaction.Commit(); } using (objTransaction = objDocument.TransactionManager.StartTransaction()) { objBlockReference = objTransaction.GetObject(oidBlockReference, OpenMode.ForWrite) as BlockReference; foreach (DynamicBlockReferenceProperty objItem in objBlockReference.DynamicBlockReferencePropertyCollection) { if (!objItem.ReadOnly && objDictionary.ContainsKey(objItem.PropertyName)) { dblValue = (double)objDictionary[objItem.PropertyName]; dblValue += 100; objItem.Value = dblValue; } } // Commit. objTransaction.Commit(); } } } } } //MessageBox.Show(strMsg, "Dynamic block properties."); }//try catch (CADR.Exception Ex) { MessageBox.Show("Error analyzing dynamic blocks: " + Ex.ToString(), "Error", MessageBoxButtons.OK, MessageBoxIcon.Error); } }
