.NET
Reading Attributes from event
2 REPLIES 2
stuartnathan
293 Views, 2 Replies
Here is some code:
Private Sub ObjectModified(ByVal sender AsObject, ByVal e As Autodesk.AutoCAD.DatabaseServices.ObjectEventArgs)
With e.DBObject
   If .IsWriteEnabled Then Exit Sub
   If .Id.ObjectClass.Name = "AcDbAttribute"Then
   End If
End With
End Sub
Trying to read the attribute's tag and text.
Can't work out what goes in ????
or do I need to get the Blockreference and work through each attribute?
I promise I will start repaying your help soon.
2 REPLIES 2
did you search for this?
With e.DBObject
  If .Id.ObjectClass.Name = "AcDbAttribute" Then
    Dim tAttRef As AttributeReference = CType(e.DBObject, AttributeReference)
    Debug.Print("TAG: " & tAttRef.Tag)
    Debug.Print("TXT: " & tAttRef.TextString)
    Debug.Print("ObjID BlockReference: " & tAttRef.OwnerId.ToString)
  End If
End With
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Smiley Very HappyObvious really. But thanks anyway. It would have taken me a week to get there.
”Boost
