.NET
ReadDWGFile Slow in ACAD2013
9 REPLIES 9
Message 1 of 10
GeeHaa
1390 Views, 9 Replies
I recently converted a vb.net program that extracts attribute data to work with ACAD2013. The program runs but is very slow It takes a full 10 minutes to read 120 small dwg files. The same program running in ACAD2010 takes about 3 seconds. Has anyone else run into this?
Thanks in Advance
G.
9 REPLIES 9
Message 2 of 10
fenton.webb
in reply to: GeeHaa
can you send us some sample code please? I'd like to test it for you to see where the problem is.
Fenton Webb
AutoCAD Engineering
Message 3 of 10
GeeHaa
in reply to: GeeHaa
For x As Integer = 0 To UBound(listOfFiles)
            Dim layoutStrings() As String = Nothing
            Dim acCurDB As New Database(False, True)
            acCurDB.ReadDwgFile(listOfFiles(x), FileOpenMode.OpenForReadAndReadShare, True, "")
              Using acTrans As Transaction = acCurDB.TransactionManager.StartTransaction
                Dim acLayoutMgr As LayoutManager
                acLayoutMgr = LayoutManager.Current
                 Dim layoutdict As DBDictionary = acTrans.GetObject(acCurDB.LayoutDictionaryId, OpenMode.ForRead)
                ReDim layoutStrings(layoutdict.Count - 2)
                For Each Ent As DBDictionaryEntry In layoutdict
                    Dim desc_Txt As String = ""
                    Dim lay As Layout = acTrans.GetObject(Ent.Value, OpenMode.ForRead)
                    Dim layBTRId As ObjectId = lay.BlockTableRecordId
                    Dim btr As BlockTableRecord = TryCast(layBTRId.GetObject(OpenMode.ForRead), BlockTableRecord)
                    If (Not lay.LayoutName = "Model") Then
                        myWS.Cells(curRow, "D") = File.GetLastWriteTime(listOfFiles(x))
                        For Each entId3 As ObjectId In btr
                            Dim ent3 As Entity = entId3.GetObject(OpenMode.ForRead)
                            Dim nextRow As Boolean = False
                            If TypeOf ent3 Is DatabaseServices.BlockReference Then
                                Dim bref As BlockReference = ent3
                                Dim atts As AttributeCollection = bref.AttributeCollection
                                For Each attId As ObjectId In atts
                                    Dim AttRef As AttributeReference = attId.GetObject(OpenMode.ForRead)
                                    Select Case AttRef.Tag
                                        Case getTags(0)
                                            If Trim(AttRef.TextString) <> "" Then
                                                myWS.Cells(curRow, "A") = AttRef.TextString
                                                myWS.Cells(curRow, "J") = fixDwgName(AttRef.TextString)
                                                myWS.Cells(curRow, "G") = ListOfNames(x)
                                        Case getTags(1)
                                                myWS.Cells(curRow, "C") = Trim(AttRef.TextString)
        Case getTags(2)
                                                myWS.Cells(curRow, "E") = Trim(AttRef.TextString)
                                        Case getTags(3)
                                                myWS.Cells(curRow, "F") = Trim(AttRef.TextString)
                                     End Select
                                Next attId
                                Dim tempstr As String = ""
                                For x2 As Integer = 4 To getTags.Count - 1
                                        If AttRef.Tag = getTags(x2) Then
                                            tempstr = tempstr + AttRef.TextString + " "
                                    Next attId
                                Next
                                If (Not Trim(tempstr) = "") Then
                                    myWS.Cells(curRow, "B") = Trim(tempstr)
                                If nextRow = True Then
                                     curRow += 1
                            'End If 'invp
                        Next entId3
                        curRow += 1
                    'MsgBox("layoutname = " + lay.LayoutName)
                Next
                acTrans.Dispose()
            End Using
            acCurDB.CloseInput(True)
        Next
 Here it is Some of it. I hope it's all you need.
Thanks Very Much
Message 4 of 10
fenton.webb
in reply to: GeeHaa
remove closeInput and also try changing the open mode to just read (no sharing)
Fenton Webb
AutoCAD Engineering
Message 5 of 10
jeff
in reply to: fenton.webb
Try commiting your transaction instead of disposing it which will call Abort
http://www.theswamp.org/index.php?topic=44037.msg493005#msg493005
You can also find your answers @ TheSwamp
Message 6 of 10
GeeHaa
in reply to: GeeHaa
Removing CloseInput helped. Still Not as fast as 2010 and it crashes at about 1600 drawings always on a different drawing though. Is anything else wrong that you can see? I also committed the Transaction instead of disposing it
Thanks Again
Message 7 of 10
fenton.webb
in reply to: GeeHaa
make sure you set the workingDatabase. Also, if you are not writing anything I recommend you use StartOpenCloseTransaction instead of StartTransaction
Fenton Webb
AutoCAD Engineering
Message 8 of 10
GeeHaa
in reply to: GeeHaa
I added your recommendations but it still crashes with the following error at around 1600 drawings out of 2100.
System.AccessViolationException was unhandled
  Message=Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
  Source=Acdbmgd
  StackTrace:
       at Autodesk.AutoCAD.Runtime.RXObject.DeleteUnmanagedObject()
       at Autodesk.AutoCAD.Runtime.DisposableWrapper.!DisposableWrapper()
       at Autodesk.AutoCAD.Runtime.DisposableWrapper.Dispose(Boolean )
  InnerException:
Message 9 of 10
_gile
in reply to: GeeHaa
You do not need to explicitly dispose your transaction as you're using a 'Using' block.
You might dispose the side Database too.
Using acCurDB As New Database(False, True)
    End Using
End Using
Gilles Chanteau
GileCAD
GitHub
Message 10 of 10
GeeHaa
in reply to: GeeHaa
Disposing of the side database worked. AS far as speed goes I was running the program in Debug Mode. The release version is as fast as 2010 if not faster.
Thanks Again
”Boost
