.NET
Member
borut.slatinsek
Message 1 of 10 (318 Views)
Read dwg extents
318 Views, 9 Replies
07-01-2011 06:29 AM
Hi!
I would like to make windows service (.NET C#), which would watch directory changes and read dwg extents, if file extension was .dwg.
Is this possible to make on machine, where autocad isn't installed?
arcticad
Message 2 of 10 (309 Views)
Re: Read dwg extents
07-01-2011 08:24 AM in reply to: borut.slatinsek
You would have to use RealDWG or OpenDesign
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=770257
http://www.opendesign.com/
(defun botsbuildbots() (botsbuildbots))
Member
borut.slatinsek
Message 3 of 10 (301 Views)
07-01-2011 09:22 AM in reply to: arcticad
Is there no free alternative?
dgorsman
Message 4 of 10 (272 Views)
07-04-2011 09:22 AM in reply to: borut.slatinsek
Could you elaborate on the reasoning behind this?  There may be "in drawing" solutions that could fulfull the requirements.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Member
borut.slatinsek
Message 5 of 10 (217 Views)
01-26-2012 01:49 AM in reply to: borut.slatinsek
I am working on application, which creates database with information of extents of DWG, TIF and other geolocated files.
Then user can click on some location on the map and check which files are under that location.
I solved all other formats, but not dwg. I can read DWG extents only inside autocad.
If there is no free solution to do this without AutoCAD, is this possible on machine that has AutoCAD installed without running autocad?
Thank you in advance!
arcticad
Message 6 of 10 (190 Views)
01-26-2012 11:01 AM in reply to: borut.slatinsek
If you don't want to pay for a solution then you will have to create an instance of AutoCAD to be able to run your code,
Valued Mentor
fieldguy
Message 7 of 10 (180 Views)
01-26-2012 01:05 PM in reply to: borut.slatinsek
Yes.  You can search here for "out of process" or "unmanaged".  There should be several examples.  What version of acad are you targeting?
arcticad
Message 8 of 10 (171 Views)
01-26-2012 02:37 PM in reply to: borut.slatinsek
I'd like to know what your referring to...
You will still have to connect to AutoCAD to run your application via ActiveX API and create an instance of AutoCAD.
You don't need to show autocad on the screen but it's still running.
Valued Mentor
fieldguy
Message 9 of 10 (166 Views)
01-26-2012 03:09 PM in reply to: fieldguy
Scratch that - sorry.  I was taking out-ot-process too literally.
Valued Contributor
FFlix
Message 10 of 10 (163 Views)
01-26-2012 03:43 PM in reply to: borut.slatinsek
hi borut
autodesk publish dxf code references as pdf file by autocad version here:
http://usa.autodesk.com/adsk/servlet/item?linkID=10809853&id=12272454&siteID=123112
it's introduction says that "The DXFformat is a tagged data representation of all the information contained in an AutoCAD® drawing file. Tagged data means that each data element in the file is preceded by an integer number that is called a group code."
so therefore i think that once you have a .dwg file saved as a .dxf file, you could write a .net application that searches this .dxf file for respective group codes and associated values; e.g. the dxf 'header variables' for drawing extents are given on p19 (i.e. from the acad2011 ref). unfortunately, i haven't done this myself, but .dxf files can be used by non-acad software.
felix
You are not logged in.
Ask the Community
