• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Member
    borut.slatinsek
    Read dwg extents
    269 Views, 9 Replies
    07-01-2011 06:29 AM
    Hi!
    I would like to make windows service (.NET C#), which would watch directory changes and read dwg extents, if file extension was .dwg.
    Is this possible to make on machine, where autocad isn't installed?
    Please use plain text.
    arcticad
    Re: Read dwg extents
    07-01-2011 08:24 AM in reply to: borut.slatinsek
    You would have to use RealDWG or OpenDesign
    http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=770257
    http://www.opendesign.com/
    “We don’t have a snowball’s chance in a blast furnace of surviving this attack unless every one of our units gets into the fight right now!”
    Member
    borut.slatinsek
    07-01-2011 09:22 AM in reply to: arcticad
    Is there no free alternative?
    dgorsman
    07-04-2011 09:22 AM in reply to: borut.slatinsek
    Could you elaborate on the reasoning behind this?  There may be "in drawing" solutions that could fulfull the requirements.
    Adopt. Adapt. Overcome. Or be overcome.
    Member
    borut.slatinsek
    01-26-2012 01:49 AM in reply to: borut.slatinsek
    I am working on application, which creates database with information of extents of DWG, TIF and other geolocated files.
    Then user can click on some location on the map and check which files are under that location.
    I solved all other formats, but not dwg. I can read DWG extents only inside autocad.
    If there is no free solution to do this without AutoCAD, is this possible on machine that has AutoCAD installed without running autocad?
    Thank you in advance!
    arcticad
    01-26-2012 11:01 AM in reply to: borut.slatinsek
    If you don't want to pay for a solution then you will have to create an instance of AutoCAD to be able to run your code,
    Valued Mentor
    01-26-2012 01:05 PM in reply to: borut.slatinsek
    Yes.  You can search here for "out of process" or "unmanaged".  There should be several examples.  What version of acad are you targeting?
    arcticad
    01-26-2012 02:37 PM in reply to: borut.slatinsek
    I'd like to know what your referring to...
    You will still have to connect to AutoCAD to run your application via ActiveX API and create an instance of AutoCAD.
    You don't need to show autocad on the screen but it's still running.
    Valued Mentor
    01-26-2012 03:09 PM in reply to: fieldguy
    Scratch that - sorry.  I was taking out-ot-process too literally.
    Valued Contributor
    FFlix
    01-26-2012 03:43 PM in reply to: borut.slatinsek
    hi borut
    autodesk publish dxf code references as pdf file by autocad version here:
    http://usa.autodesk.com/adsk/servlet/item?linkID=10809853&id=12272454&siteID=123112
    it's introduction says that "The DXFformat is a tagged data representation of all the information contained in an AutoCAD® drawing file. Tagged data means that each data element in the file is preceded by an integer number that is called a group code."
    so therefore i think that once you have a .dwg file saved as a .dxf file, you could write a .net application that searches this .dxf file for respective group codes and associated values; e.g. the dxf 'header variables' for drawing extents are given on p19 (i.e. from the acad2011 ref). unfortunately, i haven't done this myself, but .dxf files can be used by non-acad software.
    felix
