For rectangle it would be easy to doing:
[CommandMethod("testDrawLines","tdl", CommandFlags.Modal)]
public static void DrawLines()
Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
using (Transaction tr = db.TransactionManager.StartTransaction())
try
PromptEntityOptions peo = new PromptEntityOptions("\nSelect polyline: ");
peo.SetRejectMessage("Select polyline only!");
peo.AddAllowedClass(typeof(Polyline), true);
PromptEntityResult res = doc.Editor.GetEntity(peo);
if (res.Status != PromptStatus.OK) return;
Entity ent = tr.GetObject(res.ObjectId, OpenMode.ForRead, false) as Entity;
Polyline pline = ent as Polyline;
if (pline == null)
Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("No luck");
return;
Point3d lp = pline.GeometricExtents.MinPoint;
Point3d up = pline.GeometricExtents.MaxPoint;
Point3d cp = new Point3d((up.X+lp.X)/2,(up.Y+lp.Y)/2,(up.Z+lp.Z)/2);
double leng = Math.Abs(up.X - lp.X);
double wid = Math.Abs(up.Y - lp.Y);
if (leng > wid)
leng = wid;
int num = 16;
double ang = Math.PI * 2 / num;
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
for (int i = 0; i < num-1; i++)
Point3d ep = PolarPoint(cp, i * ang, leng);
Line ln = new Line(cp, ep);
Point3dCollection ips = new Point3dCollection();
ln.IntersectWith(pline, Intersect.ExtendArgument, ips,0, 0);
Point3d ip = ips[0];
ln.EndPoint = ip;
btr.AppendEntity(ln);
tr.AddNewlyCreatedDBObject(ln, true);
tr.Commit();
catch (System.Exception ex)
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(ex.Message + "\n" + ex.StackTrace);
public static Point3d PolarPoint(Point3d basepoint, double angle, double distance)
// credits to Tony Tanzillo
return new Point3d(
basepoint.X + (distance * Math.Cos(angle)),
basepoint.Y + (distance * Math.Sin(angle)),
basepoint.Z);
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
