• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Distinguished Contributor
    amitk_189
    Ray Tracing Kind
    109 Views, 3 Replies
    06-14-2012 10:08 PM
    I am doing a project where we should detect center of object and automatically draw lines in all directions
    example: Lets consider a rectangle, locate center of rectangle and draw lines on all directions
    Please use plain text.
    Hallex
    Re: Ray Tracing Kind
    06-15-2012 04:10 AM in reply to: amitk_189
    For rectangle it would be easy to doing:
            [CommandMethod("testDrawLines","tdl", CommandFlags.Modal)]
            public static void DrawLines()
                Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
                Database db = doc.Database;
                Editor ed = doc.Editor;
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    try
                        PromptEntityOptions peo = new PromptEntityOptions("\nSelect polyline: ");
                        peo.SetRejectMessage("Select polyline only!");
                        peo.AddAllowedClass(typeof(Polyline), true);
                        PromptEntityResult res = doc.Editor.GetEntity(peo);
                        if (res.Status != PromptStatus.OK) return;
                        Entity ent = tr.GetObject(res.ObjectId, OpenMode.ForRead, false) as Entity;
                        Polyline pline = ent as Polyline;
                        if (pline == null)
                            Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("No luck");
                            return;
                            Point3d lp = pline.GeometricExtents.MinPoint;
                            Point3d up = pline.GeometricExtents.MaxPoint;
                            Point3d cp = new Point3d((up.X+lp.X)/2,(up.Y+lp.Y)/2,(up.Z+lp.Z)/2);
                            double leng = Math.Abs(up.X - lp.X);
                            double wid = Math.Abs(up.Y - lp.Y);
                            if (leng > wid)
                                leng = wid;
                            int num = 16;
                            double ang = Math.PI * 2 / num;
                            BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
                            for (int i = 0; i < num-1; i++)
                                Point3d ep = PolarPoint(cp, i * ang, leng);
                                Line ln = new Line(cp, ep);
                                Point3dCollection ips = new Point3dCollection();
                                ln.IntersectWith(pline, Intersect.ExtendArgument, ips,0, 0);
                                Point3d ip = ips[0];
                                ln.EndPoint = ip;
                                btr.AppendEntity(ln);
                                tr.AddNewlyCreatedDBObject(ln, true);
                            tr.Commit();
                    catch (System.Exception ex)
                        Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(ex.Message + "\n" + ex.StackTrace);
            public static Point3d PolarPoint(Point3d basepoint, double angle, double distance)
                // credits to Tony Tanzillo
                return new Point3d(
                basepoint.X + (distance * Math.Cos(angle)),
                basepoint.Y + (distance * Math.Sin(angle)),
                basepoint.Z);
    ~'J'~
    amitk_189
    06-17-2012 11:10 PM in reply to: amitk_189
    Getting Error on
    No data is present in here and we have initilised it not assigned data
    Hallex
    06-18-2012 02:43 AM in reply to: amitk_189
    Try again
            [CommandMethod("testDrawLines", "tdl", CommandFlags.Modal)]
                    try
                        if (pline == null)
                            return;
                        Point3d cp = new Point3d((up.X + lp.X) / 2, (up.Y + lp.Y) / 2, (up.Z + lp.Z) / 2);
                        if (leng < wid)
                            leng = wid;
                        // number of lines
                        int num = 16;
                        for (int i = 0; i < num - 1; i++)
                            ln.Normal = pline.Normal;
                            ln.IntersectWith(pline, Intersect.ExtendArgument, ips, (int)IntPtr.Zero, (int)IntPtr.Zero);
                            ln.EndPoint = ip;
                        tr.Commit();
    ~'J'~
