.NET
Distinguished Contributor
VB_Autocad_guy
Message 1 of 7 (267 Views)
RasterImages
267 Views, 6 Replies
03-01-2012 02:41 PM
I think I'm going about this the wrong way.
I want to rename the RasterImage Files to Match the Drawing Naming Convention Plus a Suffix.
In this case _A, _B, _C etc.
And update that in the Drawing.
 Public Shared Sub RenameRasterImagesAndReattachToDrawing(ByVal FilePath As String)
        Dim sNewName As String = ""
        Dim iImg As Integer = 0
        Dim Suffix As String = "A"
        Dim myDwgIO As New IO.FileInfo(FilePath) 'Get FileName from Full FilePath
        '<<<1. Locate Raster Images
        'Autocad Database Adapter
        'Read Autocad File Silently without opening file on Screen
        Dim myDoc As Autodesk.AutoCAD.ApplicationServices.Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        'Start(Transaction)
        Using myTrans As Autodesk.AutoCAD.DatabaseServices.Transaction = myDoc.Database.TransactionManager.StartTransaction
            '~~~~~~~~~~~~~~~~~~~~~~~~TEMP CODE~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
            'Take a Look at Attachments
            'Open The Dictionary
            Dim nod As Autodesk.AutoCAD.DatabaseServices.DBDictionary
            Dim imageDict As Autodesk.AutoCAD.DatabaseServices.DBDictionary
            nod = CType(myTrans.GetObject(myDoc.Database.NamedObjectsDictionaryId, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite, False),  _
                        Autodesk.AutoCAD.DatabaseServices.DBDictionary)
            imageDict = CType(myTrans.GetObject(nod.GetAt("ACAD_IMAGE_DICT"), _
            For Each dicentry As Autodesk.AutoCAD.DatabaseServices.DBDictionaryEntry In imageDict
                Dim myRasterImgDef As Autodesk.AutoCAD.DatabaseServices.RasterImageDef = _
                CType(myTrans.GetObject(CType(dicentry.Value, Autodesk.AutoCAD.DatabaseServices.ObjectId), _
                                         Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite),  _
                                          Autodesk.AutoCAD.DatabaseServices.RasterImageDef)
                '<<<2. Save Information to Memory Object
                Dim TempString As String = myRasterImgDef.Handle.ToString
                'MsgBox(TempString)
                '<<<3. Rename Files (Enforce Naming Convention)
                Try
                    Dim sFileFullName As String = myRasterImgDef.SourceFileName
                    'Get File Directory
                    Dim myFileIO As System.IO.FileInfo
                    myFileIO = My.Computer.FileSystem.GetFileInfo(sFileFullName)
                    'FileName
                    Dim sFileName As String = myFileIO.Name.Substring(0, (myFileIO.Name.Length - 4))
                    'Store NewName in Memory Object
                    sNewName = myFileIO.Directory.ToString & "\" & sFileName & "_" & Suffix & ".dwg"
                    MsgBox(sNewName)
                    'Rename File
                    If Not My.Computer.FileSystem.FileExists(sNewName) Then
                        My.Computer.FileSystem.CopyFile(sFileFullName, sNewName)
                    End If
                    'Increment Letter
                    Suffix = GetNextLetter(Suffix)
                    '<<<4. Confirm Renames??
                Catch ex As Exception
                    MsgBox(ex.Message)
                End Try
                myRasterImgDef.SourceFileName = sNewName
                myRasterImgDef.ActiveFileName = sNewName
                MsgBox(myRasterImgDef.ActiveFileName & vbCrLf & myRasterImgDef.SourceFileName)
            Next
            'Commit Transaction
            myTrans.Commit()
        End Using
    End Sub
Valued Mentor
fieldguy
Message 2 of 7 (261 Views)
Re: RasterImages
03-01-2012 03:32 PM in reply to: VB_Autocad_guy
You are further along with raster images than I have gotten.  I would try to detach the old and attach the new if renaming does not work.
VB_Autocad_guy
Message 3 of 7 (236 Views)
Re: RasterImages
03-05-2012 08:08 AM in reply to: fieldguy
Thanks, I'll give it a shot.
Dale.Bartlett
Message 4 of 7 (203 Views)
Re: RasterImages
04-03-2012 03:12 AM in reply to: VB_Autocad_guy
I'm trying to do that at the moment: find and detach all images in the drawing. Seems to be trickier than it sounds, or I am half asleep... Dale
VB_Autocad_guy
Message 5 of 7 (186 Views)
Re: RasterImages
04-03-2012 10:14 AM in reply to: VB_Autocad_guy
Yah it is tricky,
Haven't figured it out yet...
But let me know if you have any luck... Or if I get around to it again I'll post my code.
Dale.Bartlett
Message 6 of 7 (175 Views)
Re: RasterImages
04-03-2012 09:18 PM in reply to: VB_Autocad_guy
Glad to know I'm not alone. I'd post some sample code but I've gone down so many rabbit holes it's shameful. I'll keep note of this page and post a solution when I get it resolved. Simply I want to detach all images in a drawing; trivial in Lisp. Regards, Dale
Dale.Bartlett
Message 7 of 7 (165 Views)
Re: RasterImages
04-04-2012 02:36 AM in reply to: Dale.Bartlett
Following code deletes all raster images in a drawing. It seems to work well, but I'm open to improvements or comment. Regards, Dale
<code>
[CommandMethod("RXC")]
        public static void RasterRemoveAll()
            Document doc = AcadApp.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            // store drawing name for error report
            string lstrDWGFileName = db.Filename.ToString();
            using(Transaction tr = db.TransactionManager.StartTransaction())
                try
                    // Tanzillo:
                    // To get your code to work in 2009, do this before you create any RasterImageDef objects:
                    RasterImage image = new RasterImage();
                    image.Dispose();
                    // These two lines of code will force the managed runtime to load the RasterImage .DBX module.
                    // who knows if needed now?
                    // open The  Named Object Dictionary
                    DBDictionary nod = tr.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForRead) as DBDictionary;
                    if(nod.Contains("ACAD_IMAGE_DICT") == false)
                        return;
                    // get the image definition dictionary id
                    ObjectId imageDictId = RasterImageDef.GetImageDictionary(db);
                    if(imageDictId == null)
                        return;
                    DBDictionary imageDict = tr.GetObject(imageDictId, OpenMode.ForRead) as DBDictionary;
                    if(imageDict.Count == 0)
                        return;
                    imageDict.UpgradeOpen();
                    // loop through all images
                    foreach(DBDictionaryEntry entry in imageDict)
                        // get the object ID of the image definition
                        imageDictId = entry.Value;
                            return;
                        // remove image definition from the dictionary
                        imageDict.Remove(imageDictId);
                        // delete image definition object
                        RasterImageDef imageDef = tr.GetObject(imageDictId, OpenMode.ForWrite) as RasterImageDef;
                        imageDef.Erase();
                    tr.Commit();
                catch(Autodesk.AutoCAD.Runtime.Exception ex)
                    MessageBox.Show(ATK_CommonLibrary.UtilityLibrary.ErrorMessage(ex, MethodBase.GetCurrentMethod().Name.ToString(), lstrDWGFileName), "Error Log");
<code>
You are not logged in.
Ask the Community
