.NET
Distinguished Contributor
vince1327
Message 1 of 4 (152 Views)
Random "OK" showing up in MTEXT
152 Views, 3 Replies
05-29-2012 08:29 AM
Hey everyone,
I've found some example code on how to create Leaderline and have been playing around with it. So far so good, but when I create my leaderline and the Mtext generates, it is always preceeded by an "OK" and i can't figure out where it's coming from. I've tried using TrimStart on a number of the strings to no avail. I know it must be something insanely simple but it can't seem to get it. Any input would be awesome!
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
namespace DimensionLibrary
    public class DimensionCommands
        static ObjectId GetArrowObjectId(string newArrName)
            ObjectId arrObjId = ObjectId.Null;
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            // Get the current value of DIMBLK
            string oldArrName = Application.GetSystemVariable("DIMBLK") as string;
            // Set DIMBLK to the new style
            // (this action may create a new block)
            Application.SetSystemVariable("DIMBLK", newArrName);
            // Reset the previous value of DIMBLK
            if (oldArrName.Length != 0)
                Application.SetSystemVariable("DIMBLK", oldArrName);
            // Now get the objectId of the block
            Transaction tr = db.TransactionManager.StartTransaction();
            using (tr)
                BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                arrObjId = bt[newArrName];
                tr.Commit();
            return arrObjId;
        [CommandMethod("MLTEST")]
        static public void CreateMultiLeader()
            Editor ed = doc.Editor;
            string bname = "";
            string bx = "";
            string by = "";
            string bz = "";
            const string arrowName = "_DOT";
            ObjectId arrId = GetArrowObjectId(arrowName);
            PromptEntityOptions options = new PromptEntityOptions("\nSelect block reference");
            options.SetRejectMessage("\nSelect only block reference");
            options.AddAllowedClass(typeof(BlockReference), false);
            PromptEntityResult acSSPrompt = ed.GetEntity(options);
            using (Transaction tx = db.TransactionManager.StartTransaction())
                BlockReference blockRef = tx.GetObject(acSSPrompt.ObjectId, OpenMode.ForRead) as BlockReference;
                BlockTableRecord block = null;
                if (blockRef.IsDynamicBlock)
                    block = tx.GetObject(blockRef.BlockTableRecord,
                                OpenMode.ForRead) as BlockTableRecord;
                    if (block.IsAnonymous)
                        //get the real dynamic block name.
                        block =
                            tx.GetObject(blockRef.DynamicBlockTableRecord,
                else
                if (block != null)
                    bname = block.Name;
                    bx = acSSPrompt.PickedPoint.X.ToString();
                    by = acSSPrompt.PickedPoint.Y.ToString();
                    bz = acSSPrompt.PickedPoint.Z.ToString();
                    ed.WriteMessage("Block name is : " + block.Name + "\n");
                    ed.WriteMessage("X is :" + bx + "\n");
                    ed.WriteMessage("Y is :" + by + "\n");
                    ed.WriteMessage("Z is :" + bz + "\n");
                tx.Commit();
                // Get the start point of the leader
                PromptPointResult result = ed.GetPoint("\nSpecify leader arrowhead location: ");
                if (result.Status != PromptStatus.OK)
                    return;
                Point3d startPt = result.Value;
                // Get the end point of the leader
                PromptPointOptions opts = new PromptPointOptions("\nSpecify landing location: ");
                opts.BasePoint = startPt;
                opts.UseBasePoint = true;
                result = ed.GetPoint(opts);
                    return;
                Point3d endPt = result.Value;
                using (tr)
                    try
                        BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
                        // Create the MLeader
                        MLeader mld = new MLeader();
                        int ldNum = mld.AddLeader();
                        int lnNum = mld.AddLeaderLine(ldNum);
                        mld.AddFirstVertex(lnNum, startPt);
                        mld.AddLastVertex(lnNum, endPt);
                        mld.ArrowSymbolId = arrId;
                        mld.LeaderLineType = LeaderType.SplineLeader;
                        // Create the MText
                        MText mt = new MText();
                        PromptStringOptions psopts = new PromptStringOptions("Please input a label for your leader line");
                        psopts.DefaultValue = bname + "\n" + "X:" + bx + "\n" + "Y:" + by + "\n" + "Z:" + bz;
                        PromptResult pres = ed.GetString(psopts);
                        mt.Contents = pres.ToString();
                        mt.Location = endPt;
                        mld.ContentType = ContentType.MTextContent;
                        mld.MText = mt;
                        // Add the MLeader
                        btr.AppendEntity(mld);
                        tr.AddNewlyCreatedDBObject(mld, true);
                        //Commit the transaction
                        tr.Commit();
                    catch
                        // Would also happen automatically
                        // if we didn't commit
                        tr.Abort();
Hallex
Message 2 of 4 (142 Views)
Re: Random "OK" showing up in MTEXT
05-29-2012 09:48 AM in reply to: vince1327
Just change this line within the code:
mt.Contents = pres.StringResult;
~'J'~
vince1327
Message 3 of 4 (139 Views)
05-29-2012 09:50 AM in reply to: Hallex
Perfect!!!!!!! Thanks again Hallex, I owe you one
Hallex
Message 4 of 4 (132 Views)
05-29-2012 10:04 AM in reply to: vince1327
Glad I could help,
Cheers, bro :smileyhappy:
~'J'~
You are not logged in.
Ask the Community
