I seem to remember reading somewhere, but I can't remember where that it is possible to manipulate some of the AutoCAd forms from a .NET plugin
For example, when a user runs the Attach Command, I want to be able to programatically set the Path type to No Path and disable the control so it can;t be changed manually
Anybody has any idea ?
Solved by Virupaksha_aithal. Go to Solution.
Are you saying the "filedia" variable? Set filedia to 0 if you do not want to see the open/save dialougue.
Daniel,
No, I'm saying for example the XRef attachment form (where you define the attachment paramters such as insertion pointm scale, roation, attachment/overlay, etc...)
Sorry, I do think, there is any API to modify the behavior of attach external reference dialog box.
