.NET
Active Contributor
btmsoftware
Message 1 of 5 (242 Views)
Question about the UI from a .NET plugin
242 Views, 4 Replies
11-21-2013 06:39 AM
I seem to remember reading somewhere, but I can't remember where that it is possible to manipulate some of the AutoCAd forms from a .NET plugin
For example, when a user runs the Attach Command, I want to be able to programatically set the Path type to No Path and disable the control so it can;t be changed manually
Anybody has any idea ?
Board Manager
Daniel.Du
Message 2 of 5 (208 Views)
Re: Question about the UI from a .NET plugin
11-22-2013 12:00 AM in reply to: btmsoftware
Are you saying the "filedia" variable?  Set filedia to 0 if you do not want to see the open/save dialougue.
Daniel Du
Developer Technical Services
Autodesk Developer Network
Active Contributor
btmsoftware
Message 3 of 5 (178 Views)
11-23-2013 12:44 AM in reply to: Daniel.Du
Daniel,
No, I'm saying for example the XRef attachment form (where you define the attachment paramters such as insertion pointm scale, roation, attachment/overlay, etc...)
ADN Support Specialist
Virupaksha.aithal
Message 4 of 5 (144 Views)
11-26-2013 02:03 AM in reply to: btmsoftware
Sorry, I do think, there is any API to modify the behavior of attach external reference dialog box.
Virupaksha Aithal KM
Active Contributor
btmsoftware
Message 5 of 5 (125 Views)
11-26-2013 10:25 PM in reply to: Virupaksha.aithal
that's what I was expecting to be honest. thanx any way for confirming
