• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Question: Using AutoCAD 2012 through an external EXE
    675 Views, 18 Replies
    03-18-2012 07:42 AM
    Hi
    I'm working on a vb.net 2010 project and want to export a dwg file So I'm trying to run AutoCAD, insert drawings and finally save the dwg file at some location.
    I found this page talking about this subject and it helped me to run autoCAD in the background and insert some drawings but when I try to save the file nothing happens, no file is saved anywhere and I can't make AutoCAD window appear.
    Can anyone help me or is there an official tutorial about this or some website that talks about it clearly?
    Thank you
    Please use plain text.
    Valued Mentor
    Mike.Wohletz
    Re: Question: Using AutoCAD 2012 through an external EXE
    03-18-2012 09:54 AM in reply to: vbNinja
    If you can't see the Application running when you start then it is because you did not tell it to be visible. The following is a sample of opening AutoCAD and saving the document.
    Public Sub StartApplication()
    Dim AcApp As AcadApplication = Nothing
    Dim AcAppName As String = "AutoCAD.Application.18"
    Dim AcAppWasStarted As Boolean = False
    Try
    ' we will connect to a running instance of AutoCAD is we have one.
    AcApp = System.Runtime.InteropServices.Marshal.GetActiveObject(AcAppName)
    Catch ex As Exception
    End Try
    If AcApp Is Nothing Then 'if it was not running then lets start the application.
    AcApp = CreateObject(AcAppName)
    AcApp.Visible = True 'true is we want to see the application running
    End If
    'Dim acDoc As AcadDocument = AcApp.ActiveDocument ' we will just get the active document
    ' if we wanted to open a document then it would be like this
    If My.Computer.FileSystem.FileExists("c:\someDocument.dwg") Then
    Dim acDoc As AcadDocument = AcApp.Documents.Open("c:\someDocument.dwg", False)
    'we will do what we want with this document
    acDoc.SaveAs("C:\savedDocument.dwg")
    If AcAppWasStarted Then ' if the application started AutoCAD then lets let the application close it.
    acDoc.Close()
    AcApp.Quit()
    End If
    End If
    End Sub
    If this does not solve your problem then please post your code on how you are trying to save the drawing..
    03-18-2012 10:14 AM in reply to: Mike.Wohletz
    Thank you very much Mike.Wohletz, That solved my problem, I feel I can't thank you enough.
    03-18-2012 01:30 PM in reply to: vbNinja
    Hi
    so I'm facing another problem, mostly when I run the code you wrote, it works, but sometimes a message box appears and it says "Call was rejected by callee. (Exception from HRESULT: 0x80010001 (RPC_E_CALL_REJECTED))"
    why does it appear randomly and what should I do?
    Thanks a lot.
    Valued Mentor
    Mike.Wohletz
    03-18-2012 03:55 PM in reply to: vbNinja
    That one can be tough to pinpoint without seeing what is going on, try adding this to the end of the code that I had posted and see if that fixes the problem.
           'before we close we need to do some cleanup
            If Not AcApp Is Nothing Then
                System.Runtime.InteropServices.Marshal.ReleaseComObject(AcApp)
                GC.Collect()
                GC.WaitForPendingFinalizers()
            End If
    03-18-2012 11:12 PM in reply to: Mike.Wohletz
    Actually the problem still exists, but here is I tried to do: I commented the acDoc.Close() and AcApp.Quit() out, then I opened AutoCAD manually and then ran my program, and it worked perfectly so is it possible that sometimes AutoCAD is not running properly?
    Thank you
    chiefbraincloud
    03-19-2012 07:29 PM in reply to: vbNinja
    This is a problem that appeared after AutoCAD 2010 Update 1.  The problem, and the solution, is explained in this Through the Interface POST
    You need to implement a reasonably simple iMessageFilter to retry the COM call if it is rejected.
    03-20-2012 01:16 PM in reply to: chiefbraincloud
    Hi
    I read your linked article and to be honest I don't know anything about C#, I tried to convert the code to vb.net using some website, but this produces errors that I don't know how to handle.
    But I found a solution based on a theory that came up with, the theory says that AutoCAD is not ready to recieve commands whan I am trying to draw on it, so I need to wait for to get ready, but since I don't know how long should I wait, I assumed that 4 seconds is enough, so I insert this line:
    System.Threading.Thread.Sleep(4000)
    right before the code responsible for drawing and actually it worked like a miracle.
    Thank you chiefbraincloud and Mike.Wohletz for your help, I really appreciate it.
    chiefbraincloud
    03-20-2012 01:41 PM in reply to: vbNinja
    While it may seem to have solved your problem, waiting 4 seconds will NOT gaurauntee success every time, and it is possible to have a COM call rejected at other times besides when starting the program.
    I have clipped out a VB version of the important code from the TTIF post and attached it here as a .txt file.  See if you can follow the couple of comments I put in, and merge this code into your form code (or vice/versa).  This code worked for me in the only COM code I have which is an installer that opens AutoCAD to create a new profile and workspace using the current ones as a starting point.
    03-21-2012 06:46 AM in reply to: chiefbraincloud
    Hi
    So I removed the sleep command and inserted your code and an exception occures at line (Dim doc As AcadDocument = acApp.ActiveDocument) and it says:
    The message filter indicated that the application is busy. (Exception from HRESULT: 0x8001010A(RPC_E_SERVERCALL_RETRYLATER))
    what is the problem now?
