Query to Filter Data in .NET
Hi
I am trying to Apply Location query on Query to Filter Data in .NET
Anyone please provide the sample code or procedure to program
Dayalan
For which vertical? Civil/Map3d?
I am not sure for what you want. You can use Predicate delegate (with Invoke method) for your custom query inside the loop. Or you can use LINQ with where condition.
-Khoa
Hi all,
I am using AutoCAD Map3d Enterprise 2012.
We have "Query to Filter data" out-of-box functionality. In this i want to apply "Location" query filter using .net programming
Some one please help me...
Regards
Dayalan
Here is an example that should get you going. I believe that I have posted something similiar on the Map3d forum a few years back. You may have better luck there.
public void getbasemap()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = HostApplicationServices.WorkingDatabase;
            ProjectModel prjModel = HostMapApplicationServices.Application.ActiveProject;
            string current_projection = prjModel.Projection;
            ProjectOptions prjOptions = prjModel.Options;
            DrawingSet drawingset = prjModel.DrawingSet;
            MapApplication mapApi = HostMapApplicationServices.Application;
            //Yes, we need to use an alias
			Aliases aliases = mapApi.Aliases;
            string The_Keymap_alias = "FinalPathToKeymapDWG";
            //Go get the file name
			string The_Keymap = Get_(ref CWDS, "FinalPathToKeymapDWG");
            //Remove Alias
            try
                aliases.RemoveAlias(The_Keymap_alias);
            catch (MapException)
                doc.Editor.WriteMessage("\nFailed to remove alias ... probably OK.");
            //Add Alias
            try
                aliases.AddAlias(The_Keymap_alias, The_Keymap);
                doc.Editor.WriteMessage("\nFailed to add alias. NOT good.");
            drawingset.AttachDrawing(The_Keymap_alias);
			//Get the current query and set the mode draw/preview...
            QueryModel qryModel = prjModel.CurQuery;
            qryModel.Mode = Autodesk.Gis.Map.Constants.QueryType.QueryDraw;
            qryModel.Clear();
            // The root query object
            QueryBranch qb_root = QueryBranch.Create();
            // By location condition
			// No need for window locationtype here I want the entire drawing
            LocationCondition locationcondition = new LocationCondition();
            locationcondition.LocationType = Autodesk.Gis.Map.Constants.LocationType.LocationCrossing;
            locationcondition.Boundary = AllBoundary.Create();
            // Make a branch
            QueryBranch qblocation = QueryBranch.Create();
            qblocation.AppendOperand(locationcondition);
            // append it to the root
            qb_root.AppendOperand(qblocation);
            // By Properties condition
            PropertyCondition propertycondition = new PropertyCondition();
            propertycondition.JoinOperator = Autodesk.Gis.Map.Constants.JoinOperator.OperatorAnd;
            propertycondition.PropertyType = Autodesk.Gis.Map.Constants.PropertyType.Layer;
            propertycondition.ConditionOperator = Autodesk.Gis.Map.Constants.ConditionOperator.ConditionEqual;
			//Go get the list of layers
            string The_KeymapLayers = Get_(ref CWDS, "KeymapLayers");
            propertycondition.Value = The_KeymapLayers;
            // Make a branch
            QueryBranch qbproperties = QueryBranch.Create();
            qbproperties.AppendOperand(propertycondition);
            qb_root.AppendOperand(qbproperties);
            // Construct it
            qryModel.Define(qb_root);
            // Execute it
            ObjectIdCollection queried_keymap_objs_collection = qryModel.Execute(drawingset);
            // some local cleanup
            qb_root.Clear();
            qblocation.Clear();
            qbproperties.Clear();
            qryModel.Clear();
            locationcondition.Dispose();
            // Now we wish to see everything so that we can construct the Viewports for the small
            // viewport the contains the "whole" drawing.
            AcadApplication pApp;
            pApp = (Autodesk.AutoCAD.Interop.AcadApplication)Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
            pApp.ZoomExtents();
            // These globals are used for/by the Viewports
            KEYMAP_EXTENTS_MAX = db.Extmax;
            KEYMAP_EXTENTS_MIN = db.Extmin;
            KEYMAP_EXTENTS_center = new Point2d((KEYMAP_EXTENTS_MAX.X + KEYMAP_EXTENTS_MIN.X) / 2, (KEYMAP_EXTENTS_MAX.Y + KEYMAP_EXTENTS_MIN.Y) / 2);
            drawingset.DetachDrawing(The_Keymap_alias);
 r,
dennis
Thanks for reply.  I am able to create my own Query to filte data using Location on map option in C#.net. But The below last refresh option is not working.
I could see the applied query in Create query form. but it is not refreshed on map.
Any one please help me.
stringgeometryName = parcelsLayer1.GetFeatureGeometryName();
MgByteReadergeometryData = featureReader.GetGeometry(geometryName);
MgAgfReaderWriter agfReaderWriter = newMgAgfReaderWriter();
MgGeometrygeometry = agfReaderWriter.Read(geometryData);
MgPolygon mgPoly = geometry asMgPolygon;
MgWktReaderWriter wktReaderWriter = newMgWktReaderWriter();
stringwkt = wktReaderWriter.Write(mgPoly);
wkt = wkt.Replace(
"POLYGON", "POLYGON XYZ ");
wkt = wkt.Replace(
",", " 0,");
wkt = wkt.Replace(
"))", " 0))");
string filter = "GEOM INSIDE GeomFromText('" + wkt + "')";
AcMapLayer layer1 = mgLayColl.GetItem("EL_CONDUCTOR") asAcMapLayer;
MgResourceIdentifierlayerDefId = layer1.GetLayerDefinition();
MgResourceService rs = AcMapServiceFactory.GetService(MgServiceType.ResourceService) asMgResourceService;
MgByteReaderlayerReader = rs.GetResourceContent(layerDefId);
XmlDocument objXML = newXmlDocument();
XmlSerializer objSerializer = newXmlSerializer(typeof(LayerDefinition));
LayerDefinition objLayerDef = objSerializer.Deserialize(newStringReader(layerReader.ToString())) asLayerDefinition;
VectorLayerDefinitionType objVectorLayerDef = objLayerDef.Item asVectorLayerDefinitionType;
objVectorLayerDef.Filter = filter;
StringWriter objWriter = newStringWriter();
XmlSerializer objXs = newXmlSerializer(typeof(LayerDefinition));
objXs.Serialize(objWriter, objLayerDef);
byte[] unicodeBytes = Encoding.Unicode.GetBytes(objWriter.ToString());
byte[] utf8Bytes = Encoding.Convert(Encoding.Unicode, Encoding.UTF8, unicodeBytes);
MgByteSource objSource = newMgByteSource(utf8Bytes, utf8Bytes.Length);
rs.SetResource(layer1.LayerDefinition, objSource.GetReader(),
null);
layer1.NeedsRefresh();
layer1.ForceRefresh();
Please, be a good citizen and use the correct forum. The Map3d Developer and the OSGeo Mapguide forums. I am very sure these folks would appreciate it. I know I will.
r,
dennis
