.NET
Query report text
2 REPLIES 2
545 Views, 2 Replies
Query report text
I would like to create a text file with from a report. here is my code so far....
                    '' Clear the existing Query
                    Dim qryModel As QueryModel = proj.CreateQuery()
                    qryModel.Clear()
                    Dim qryBranch As New QueryBranch(Constants.JoinOperator.OperatorAnd)
                    '' Property Condition
                    Dim propertyCondition As PropertyCondition = New PropertyCondition
                    propertyCondition.JoinOperator = Constants.JoinOperator.OperatorAnd
                    propertyCondition.PropertyType = Constants.PropertyType.Layer
                    propertyCondition.ConditionOperator = Constants.ConditionOperator.ConditionEqual
                    propertyCondition.Value = "CP*"
                    qryBranch.AppendOperand(propertyCondition)
                    qryModel.Define(qryBranch)
                    qryModel.Mode = Constants.QueryType.QueryReport
                    qryModel.ReportTemplate.AddLine(":CIRCUIT@CIRCUIT")
                    qryModel.ReportTemplate.AddLine(".DWGNAME")
                    qryModel.Execute(dwgSet)
                    qryModel.Run()
 can you help me to send data to a text file?
2 REPLIES 2
Alfred.NESWADBA
is that the line you are missing (based on your code):
      'last lines based on your code (after adding .DWGNAME):
      'define your output file
      qryModel.ReportTemplate.FileName = "C:\TEMP\ReportResult.TXT"
      'removed ... qryModel.Execute(dwgSet)
      qryModel.Run()
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Correct! Thanks again.
”Boost
