.NET
Purgeall
7 REPLIES 7
Message 1 of 8
1150 Views, 7 Replies
Purgeall
Needed help in the following solution.
doc.SendStringToExecute("_-Purge _A _* _N ", True, False, False)
7 REPLIES 7
Message 2 of 8
Alexander.Rivilis
What help do you need?
Maybe simplest sample:
using System;
using System.Reflection;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
[assembly: CommandClass(typeof(Rivilis.Purge))]
namespace Rivilis
  public class Purge
    [CommandMethod("MyPurgeAll")]
    static public void MyPurgeAll()
      // For AutoCAD 2013+
      object adoc = Application.DocumentManager.MdiActiveDocument.GetAcadDocument();
      // For AutoCAD 2012-
      // object adoc = Application.DocumentManager.MdiActiveDocument.AcadDocument;
      if (adoc != null) {
        adoc.GetType().InvokeMember("PurgeAll",BindingFlags.InvokeMethod, null, adoc, null);
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 8
in reply to: Alexander.Rivilis
Thanks Alexander
i have this message:
Error 1 'GetAcadDocument' is not a member of 'Autodesk.AutoCAD.ApplicationServices.Document'.
Message 4 of 8
Hi Alexander,
the code works ok, but I have though a question: I have a drawing that was last saved in paper space (paper space being active space).
When I open up the drawing and try to run the code (just as the first command in the drawing), it doesn't run. Although if I enter model space through viewport or switch back and forth between model space and paper space, the code will run as supposed to.
I don't know what is missing.
e.g.
Message 5 of 8
Alexander.Rivilis
@Anonymous wrote:
Thanks Alexander
This is because you did not read the comments in the program. Read them carefully.
@Anonymous wrote:
...When I open up the drawing and try to run the code (just as the first command in the drawing), it doesn't run. Although if I enter model space through viewport or switch back and forth between model space and paper space, the code will run as supposed to...
Sorry but I can not reproduce this behavior.
Expert Elite Member
Message 6 of 8
I was just telling myself, as an uneducated programming hobbyiest writing addins for myself only, that modifying geometry in CAD so far has been fairly straight forward, but there was no way I could figure out how to "purge all".... VUALA! Magic appears at Autodesk 🙂
Thanks Alexander (or is it Alex?)
One more question... I couldn't help but notice the difference in the adoc dealio... everything I've written for myself has been for 2012... are you showing me that I'll have to update every flippin acdoc in my code when I update to 2013?  sad face lol
Thanks!
"Very funny, Scotty. Now beam down my clothes.
Message 7 of 8
Resolved
Thanks Alexander
Message 8 of 8
This code have to work in both AutoCAD 2012 (and 2011, 2010...) and AutoCAD 2013:
using System;
namespace Rivilis
  public class Purge
      Document doc = Application.DocumentManager.MdiActiveDocument;
      object adoc = null;
      if (Application.Version.Major < 19) {
        // For AutoCAD 2012- (i.e. 2012, 2011, 2010, ...)
        adoc = doc.GetType().InvokeMember("AcadDocument",
          BindingFlags.GetProperty, null, doc, null);
      } else {
        // For AutoCAD 2013+ (i.e. 2013, 2014 (???), ...)
        Type ext = typeof(Autodesk.AutoCAD.Windows.Menu).Assembly
.GetType("Autodesk.AutoCAD.ApplicationServices.DocumentExtension", true); MethodInfo GetAcadDocumentMethod = ext.GetMethod("GetAcadDocument", BindingFlags.Public | BindingFlags.Static); adoc = GetAcadDocumentMethod.Invoke(doc, new object[1] { doc }); } if (adoc != null) { adoc.GetType().InvokeMember("PurgeAll", BindingFlags.InvokeMethod, null, adoc, null); } } } }
Expert Elite Member
”Boost
