• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Valued Contributor
    Ertqwa
    Projecting a circle on default UCS
    282 Views, 7 Replies
    12-22-2012 06:11 AM
    I have a cirlce which is rotated 45 degree around the X-axis. If you look at it from the top (normal=0,0,1) it will look like an ellipse.
    I want to draw a new entity (ELLIPSE) that will have the same shape/look as the circle viewed from the top, but the whole entity must have z=0.
    Basically, exactly what the command FLATTEN does.
    Is there a way to do this easily? Or is the only way to figure out the math behind it? Does anyone know a site where this math is explained?
    Thank you.
    Please use plain text.
    Moderator
    Alexander.Rivilis
    Re: Projecting a circle on default UCS
    12-22-2012 07:40 AM in reply to: Ertqwa
    Try this code:
    using System;
    using System.Runtime.InteropServices;
    using Autodesk.AutoCAD.Runtime;
    using Autodesk.AutoCAD.ApplicationServices;
    using Autodesk.AutoCAD.EditorInput;
    using Autodesk.AutoCAD.Geometry;
    using Autodesk.AutoCAD.DatabaseServices;
    [assembly: CommandClass(typeof(Rivilis.CurveProject))]
    namespace Rivilis
      public class CurveProject
        [CommandMethod("CrvPrjUCS")]
        static public void CrvPrjUCS()
          Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
          Database db = Application.DocumentManager.MdiActiveDocument.Database;
          PromptEntityOptions opt = new PromptEntityOptions("\nSelect a Curve: ");
          opt.SetRejectMessage("Not a Curve");
          opt.AddAllowedClass(typeof(Curve), false);
          PromptEntityResult rs = ed.GetEntity(opt);
          Matrix3d mat = ed.CurrentUserCoordinateSystem;
          Plane pln = new Plane(Point3d.Origin, Vector3d.ZAxis);
          pln.TransformBy(mat);
          if (rs.Status == PromptStatus.OK) {
            using (Transaction tr = db.TransactionManager.StartTransaction()) {
              Curve crv = tr.GetObject(rs.ObjectId, OpenMode.ForRead) as Curve;
              if (crv != null) {
                Curve newCrv = crv.GetOrthoProjectedCurve(pln);
                if (newCrv != null) {
                  BlockTableRecord btr = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
                  if (btr != null) {
                    btr.AppendEntity(newCrv);
                    tr.AddNewlyCreatedDBObject(newCrv, true);
                  } else {
                    newCrv.Dispose();
              tr.Commit();
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
    12-22-2012 02:58 PM in reply to: Alexander.Rivilis
    Hi Alexander,
    I noticed the GetOrthoProjectedCurve() and GetProjectedCurve() methods gave unexpected results with polylines (all types).
    You can have a look at the GetOrthoProjectedPolyline() and GetProjectedPolyline() extension methods for Polyline, Polyline2d and Polyline3d classes in the GeometryExtension library here:
    http://www.theswamp.org/index.php?topic=31865.msg373672#msg373672
    Gilles Chanteau
    Hallex
    12-23-2012 02:12 AM in reply to: _gile
    Have disagree this code by Alexander is working good enough with aby type of curves [CommandMethod("3ps")] public static void test3dp() { // some dummy points for test Point3dCollection points = new Point3dCollection() { new Point3d(5, 15, 10), new Point3d(25, 20, 0), new Point3d(30, 5, -10), new Point3d(10, 10, 5) }; // create closed 3dpoly create3dPoly(HostApplicationServices.WorkingDatabase, points, true); } // code borrowed from Fenton Webb, Autodesk, 15/06/2012 static public void create3dPoly(Database db,Point3dCollection points,bool closed) { Transaction tr = db.TransactionManager.StartTransaction(); using (tr) { // Create a 3D polyline with two segments (3 points) using (Polyline3d poly3d = new Polyline3d()) { poly3d.SetDatabaseDefaults(); // Add the new object to the current space block table record using (BlockTableRecord btr = tr.GetObject(db.CurrentSpaceId,OpenMode.ForWrite) as BlockTableRecord) { // because before adding vertexes, the polyline must be in the drawing btr.AppendEntity(poly3d); foreach (Point3d pnt in points) { // now create the vertices using (PolylineVertex3d poly3dVertex = new PolylineVertex3d(pnt)) // and add them to the 3dpoly (this adds them to the db also poly3d.AppendVertex(poly3dVertex); } } poly3d.Closed = closed; } tr.Commit(); }//end using transaction }
    Moderator
    Alexander.Rivilis
    12-23-2012 03:17 AM in reply to: _gile
    Hi, Gilles!
    You probably right, but I've tested this code with different types of polylines in AutoCAD 2013 and found no problems. Maybe you can clarify the conditions in which these problems arise?
    12-23-2012 09:09 AM in reply to: Alexander.Rivilis
    Ok, with A3013 GetOrthoProjectedCurve() seems to work as expected with Polyline entities, but I still have unexpected results with Polyline2d entities (wrong elevation).
    With prior AutoCAD versions GetOrthoProjectedCurve() raised a eNotApplicable exception with Polyline entities and gave unpredictable reulst with Polyline2d entities.
    Gilles Chanteau
    Moderator
    Alexander.Rivilis
    12-23-2012 09:15 AM in reply to: _gile
    _gile wrote:
    Ok, with A3013 ...
    We already live in the fourth millennium after Christ? :smileyhappy:
    Valued Contributor
    Ertqwa
    02-17-2013 11:46 AM in reply to: Alexander.Rivilis
    It's a bit late reply, but....great ty!
