Hi, I got some Problems with the ACAD Application.
I want to get a running instance of ACAD. This is the code I use for it.
PublicFunction ACAD_Running() As Autodesk.AutoCAD.Interop.AcadApplication ACAD_Running = GetObject(,"AutoCAD.Application") EndFunction
And it's working.
So I can read the caption, the preferences and so on.
But sometimes, vb.net told me:
Der öffentliche Member [...] für den Typ IAcadApplication wurde nicht gefunden.
The public Member [...] of Type IAcadApplication was not found.
[...] stands for different types of elements.
I see, there's a difference between IAcadApplication and AcadApplication. But I define ACAD_Running as AcadApplication, so where's the mistake I've made?
Best Regards
Passi
It is tough to suggest what is causing issue at your end by the information give. Can you please provide us a sample (non confidential) using which we can try to simulate the issue at our end?
