I have this issue:
I have installed on my computer:
Excel 2010 32 bits, Office connectivity tool 2010 64 bits, Autocad 2011 64 bits and ofcourse Visual studio
My task is to read an excel spreadsheet and insert some points in autocad
The fastest way for me is to connect to Excel using database connectivity
The speed for my is very important
Dim ConnectionString2 As String = _
"Provider=Microsoft.ACE.OLEDB.12.0;Data Source=" & nume_fisier_excel_activ & ";" & _
"Extended Properties=" & Chr(34) & "Excel 12.0;HDR=NO;IMEX=1" & Chr(34)
and
Dim SQL_String_select_all As String = "SELECT * FROM [" & nume_sheet_curent & "]"
Using Connection1 As New System.Data.OleDb.OleDbConnection(ConnectionString2)
Connection1.Open()
Using Command1 As New System.Data.OleDb.OleDbCommand(SQL_String_select_all, Connection1)
Using Adapter1 As New System.Data.OleDb.OleDbDataAdapter(Command1)
Adapter1.Fill(Table1)
End Using
End Using
End Using
This works very well when I am using this into a program outside autocad ( standalone app)
When I am using it inside autocad says ACE.OLEDB.12.0 not registered on the local machine
if I try to compile the dll as 32 bits does not load into my autocad 64 bits
I do not want to read the excel file as csv or such I want to use database connectivity
A solution would be to create the datatable outside autocad with a stand alone application put it into clipboard with
Clipboard.SetDataObject(Table1)
and accesss the datatable from inside autocad.
How and if is possible to do that? There is another way to read very fast excel spreadsheet and load it into a datatable into autocad?
I believe your problem is that the OLE driver you're using to connect to Excel 32-bit is a 32-bit DLL - and you can't load 32-bit DLLs into a 64-bit process space (AutoCAD 64-bit in this case).
That being the case, your options are:
1. Install Office 64-bit instead of Office 32-bit - so you can use a 64-bot driver DLL.
2. House your code to access Excel in a standalone executable and expose an IPC interface that AutoCAD can access (e.g. a COM interface).
Cheers,
Stephen Preston
Autodesk Developer Network
Because of all the 32\64bit problems we quit using COM to get to Excel, you can use the Microsoft OpenXML sdk to read/write Excel & Word files directly without having to have either application installed (only works on Office 2007/2010 files).
@michael.robertson wrote:Because of all the 32\64bit problems we quit using COM to get to Excel, you can use the Microsoft OpenXML sdk to read/write Excel & Word files directly without having to have either application installed (only works on Office 2007/2010 files).
Hi Micheal...
I have the same issues as the OP. Would you mind elaborating on your method of accessing data via XML/Excel? I am fairly new to .NET and am still trying to figure all of this out, so the simpler the better! 🙂 I don't even know were to begin with XML data.
I have a simple data set (basically points the I need to input into AutoCAD) that currently reside in an Excel file. I need AutoCAD to read that file so I can input the points into the DB.
The data file will be used in many projects and input by many different users, so it needs to be universal enough to allow someone to easily input the new point data. Any ideas?
Thanks!
You can get information. example code, and download the OpenXML from here:
http://msdn.microsoft.com/en-us/library/bb448854.aspx
It provides a number of dll files that you can reference from your .NET application and deliver with your final product (the end user doesn't need to install the SDK, they only need the dll(s) referenced in your product).
To open and xlsx file you need to make a reference in your project ot the DocumentFormat.OpenXml.dll file in the SDK, I'm using VB .NET so also you need to import:
Imports DocumentFormat.OpenXml.Packaging
Imports DocumentFormat.OpenXml.Spreadsheet
Then you can access the xlsx file with
Using document As SpreadsheetDocument = SpreadsheetDocument.Open(xlsxFilename, False)
'do your processing here
End Using
You are welcome. This has really sped up our apps that need to read/write excel data and we are no longer locked into the user having to have Excel installed (or have a specific version)!
Try this class Imports System Imports System.Collections.Generic Imports System.Text Imports System.Drawing Imports System.IO Imports System.Reflection Imports System.Runtime.InteropServices Imports Microsoft.VisualBasic Imports System.Globalization '============= Last edition date 06//22/11 =============' ' mostly borrowed from: ' http://www.sql.ru/forum/actualthread.aspx?tid=620401&pg=1 Namespace ExcelReflectVB Public Class Excel Implements IDisposable Public Const UID As String = "Excel.Application" Private oExcel As Object = Nothing Private WorkBooks As Object, WorkBook As Object, WorkSheets As Object, WorkSheet As Object, Range As Object, Interior As Object 'Constructor Public Sub New() oExcel = Activator.CreateInstance(Type.GetTypeFromProgID(UID)) End Sub 'Set Visible property Public WriteOnly Property Visible() As Boolean Set(ByVal value As Boolean) If False = value Then oExcel.GetType().InvokeMember("Visible", BindingFlags.SetProperty, Nothing, oExcel, New Object() {False}) Else oExcel.GetType().InvokeMember("Visible", BindingFlags.SetProperty, Nothing, oExcel, New Object() {True}) End If End Set End Property ' Get WorkBook Public Function GetWorkBook(ByVal booknumber As Integer) As Object WorkBooks = oExcel.GetType().InvokeMember("Workbooks", BindingFlags.GetProperty, Nothing, oExcel, Nothing) Return WorkBooks.GetType().InvokeMember("Item", BindingFlags.GetProperty, Nothing, WorkBooks, New Object() {booknumber}) End Function ' Get ActiveWorkBook Public Function ActiveDocument() As Object Return oExcel.GetType().InvokeMember("ActiveWorkBook", BindingFlags.GetProperty, Nothing, oExcel, Nothing) End Function ' Get Sheet By Number Public Function ActiveSheet(ByVal WorkBook As Object, ByVal sheetnumber As Integer) As Object WorkSheets = WorkBook.GetType().InvokeMember("Worksheets", BindingFlags.GetProperty, Nothing, WorkBook, Nothing) Return WorkSheets.GetType().InvokeMember("Item", BindingFlags.GetProperty, Nothing, WorkSheets, New Object() {sheetnumber}) End Function ' Get UsedRange Public Function GetUsedRange(ByVal WorkSheet As Object) As Object Return WorkSheet.GetType().InvokeMember("UsedRange", BindingFlags.GetProperty, Nothing, WorkSheet, Nothing) End Function ' Get Range By Address Public Function GetRange(ByVal WorkSheet As Object, ByVal address As Object()) As Object Return WorkSheet.GetType().InvokeMember("Range", BindingFlags.GetProperty, Nothing, WorkSheet, address) End Function 'Get Range Value Public Function GetRangeValue(ByVal Range As Object) As Object Return Range.GetType().InvokeMember("Value", BindingFlags.GetProperty, Nothing, Range, Nothing) End Function ' Set Range Value Public Sub SetRangeValue(ByVal Range As Object, ByVal value As Object) Range.GetType().InvokeMember("Value", BindingFlags.SetProperty, Nothing, Range, New Object() {value}) End Sub 'Get Range Row Public Function GetRangeColumn(ByVal Range As Object) As Integer Return Convert.ToInt32(Range.GetType().InvokeMember("Row", BindingFlags.GetProperty, Nothing, Range, Nothing)) End Function 'Get Range Column Public Function GetRangeRow(ByVal Range As Object) As Integer Return Convert.ToInt32(Range.GetType().InvokeMember("Column", BindingFlags.GetProperty, Nothing, Range, Nothing)) End Function 'Get number of Columns in the Range Public Function ColumnsCount(ByVal Range As Object) As Integer Dim RangeColumns As Object = Range.GetType().InvokeMember("Columns", BindingFlags.GetProperty, Nothing, Range, Nothing) Return Convert.ToInt32(RangeColumns.GetType().InvokeMember("Count", BindingFlags.GetProperty, Nothing, RangeColumns, Nothing)) End Function 'Get number of Rows in the Range Public Function RowsCount(ByVal Range As Object) As Integer Dim RangeRows As Object = Range.GetType().InvokeMember("Rows", BindingFlags.GetProperty, Nothing, Range, Nothing) Return Convert.ToInt32(RangeRows.GetType().InvokeMember("Count", BindingFlags.GetProperty, Nothing, RangeRows, Nothing)) End Function Public Sub SetText(ByVal Range As Object, ByVal text As String) Range.GetType().InvokeMember("Value2", BindingFlags.SetProperty, Nothing, Range, New Object() {text}) End Sub 'Open Document Public Sub OpenDocument(ByVal name As String) WorkBooks = oExcel.GetType().InvokeMember("Workbooks", BindingFlags.GetProperty, Nothing, oExcel, Nothing) WorkBook = WorkBooks.GetType().InvokeMember("Open", BindingFlags.InvokeMethod, Nothing, WorkBooks, New Object() {name, True}) WorkSheets = WorkBook.GetType().InvokeMember("Worksheets", BindingFlags.GetProperty, Nothing, WorkBook, Nothing) WorkSheet = WorkSheets.GetType().InvokeMember("Item", BindingFlags.GetProperty, Nothing, WorkSheets, New Object() {1}) End Sub 'Create new document Public Sub NewDocument() WorkBooks = oExcel.GetType().InvokeMember("Workbooks", BindingFlags.GetProperty, Nothing, oExcel, Nothing) WorkBook = WorkBooks.GetType().InvokeMember("Add", BindingFlags.InvokeMethod, Nothing, WorkBooks, Nothing) WorkSheets = WorkBook.GetType().InvokeMember("Worksheets", BindingFlags.GetProperty, Nothing, WorkBook, Nothing) WorkSheet = WorkSheets.GetType().InvokeMember("Item", BindingFlags.GetProperty, Nothing, WorkSheets, New Object() {1}) Range = WorkSheet.GetType().InvokeMember("Range", BindingFlags.GetProperty, Nothing, WorkSheet, New Object(0) {"A1"}) End Sub 'Close Document Public Sub CloseDocument() WorkBook.GetType().InvokeMember("Close", BindingFlags.InvokeMethod, Nothing, WorkBook, New Object() {True}) End Sub 'Save Document Public Sub SaveDocument(ByVal name As String) If File.Exists(name) Then WorkBook.GetType().InvokeMember("Save", BindingFlags.InvokeMethod, Nothing, WorkBook, Nothing) Else WorkBook.GetType().InvokeMember("SaveAs", BindingFlags.InvokeMethod, Nothing, WorkBook, New Object() {name}) End If End Sub 'Set cell background color Public Sub SetColor(ByVal range As String, ByVal r As Integer) 'Range.Interior.ColorIndex range = WorkSheet.GetType().InvokeMember("Range", BindingFlags.GetProperty, Nothing, WorkSheet, New Object() {range}) Interior = range.GetType().InvokeMember("Interior", BindingFlags.GetProperty, Nothing, range, Nothing) range.GetType().InvokeMember("ColorIndex", BindingFlags.SetProperty, Nothing, Interior, New Object() {r}) End Sub 'Page orientation enums Public Enum XlPageOrientation xlPortrait = 1 'portrait xlLandscape = 2 ' landscape End Enum 'Set page orientation Public Sub SetOrientation(ByVal Orientation As XlPageOrientation) Dim PageSetup As Object = WorkSheet.GetType().InvokeMember("PageSetup", BindingFlags.GetProperty, Nothing, WorkSheet, Nothing) PageSetup.GetType().InvokeMember("Orientation", BindingFlags.SetProperty, Nothing, PageSetup, New Object() {2}) End Sub 'Set page margins Public Sub SetMargin(ByVal Left As Double, ByVal Right As Double, ByVal Top As Double, ByVal Bottom As Double) Dim PageSetup As Object = WorkSheet.GetType().InvokeMember("PageSetup", BindingFlags.GetProperty, Nothing, WorkSheet, Nothing) PageSetup.GetType().InvokeMember("LeftMargin", BindingFlags.SetProperty, Nothing, PageSetup, New Object() {Left}) PageSetup.GetType().InvokeMember("RightMargin", BindingFlags.SetProperty, Nothing, PageSetup, New Object() {Right}) PageSetup.GetType().InvokeMember("TopMargin", BindingFlags.SetProperty, Nothing, PageSetup, New Object() {Top}) PageSetup.GetType().InvokeMember("BottomMargin", BindingFlags.SetProperty, Nothing, PageSetup, New Object() {Bottom}) End Sub 'Page size enums Public Enum xlPaperSize xlPaperA4 = 9 xlPaperA4Small = 10 xlPaperA5 = 11 xlPaperLetter = 1 xlPaperLetterSmall = 2 xlPaper10x14 = 16 xlPaper11x17 = 17 xlPaperA3 = 9 xlPaperB4 = 12 xlPaperB5 = 13 xlPaperExecutive = 7 xlPaperFolio = 14 xlPaperLedger = 4 xlPaperLegal = 5 xlPaperNote = 18 xlPaperQuarto = 15 xlPaperStatement = 6 xlPaperTabloid = 3 End Enum 'Set paper size Public Sub SetPaperSize(ByVal Size As xlPaperSize) Dim PageSetup As Object = WorkSheet.GetType().InvokeMember("PageSetup", BindingFlags.GetProperty, Nothing, WorkSheet, Nothing) PageSetup.GetType().InvokeMember("PaperSize", BindingFlags.SetProperty, Nothing, PageSetup, New Object() {Size}) End Sub 'Set page setup scale Public Sub SetZoom(ByVal Percent As Integer) Dim PageSetup As Object = WorkSheet.GetType().InvokeMember("PageSetup", BindingFlags.GetProperty, Nothing, WorkSheet, Nothing) PageSetup.GetType().InvokeMember("Zoom", BindingFlags.SetProperty, Nothing, PageSetup, New Object() {Percent}) End Sub 'Rename sheet Public Sub ReNamePage(ByVal n As Integer, ByVal Name As String) Dim Page As Object = WorkSheets.GetType().InvokeMember("Item", BindingFlags.GetProperty, Nothing, WorkSheets, New Object() {n}) Page.GetType().InvokeMember("Name", BindingFlags.SetProperty, Nothing, Page, New Object() {Name}) End Sub 'Add sheet Public Sub AddNewPage(ByVal Name As String) WorkSheet = WorkSheets.GetType().InvokeMember("Add", BindingFlags.GetProperty, Nothing, WorkSheets, Nothing) Dim Page As Object = WorkSheets.GetType().InvokeMember("Item", BindingFlags.GetProperty, Nothing, WorkSheets, New Object() {1}) Page.GetType().InvokeMember("Name", BindingFlags.SetProperty, Nothing, Page, New Object() {Name}) End Sub 'Set cell font Public Sub SetFont(ByVal range As String, ByVal font As Font) 'Range.Font.Name range = WorkSheet.GetType().InvokeMember("Range", BindingFlags.GetProperty, Nothing, WorkSheet, New Object() {range}) font = range.GetType().InvokeMember("Font", BindingFlags.GetProperty, Nothing, range, Nothing) range.GetType().InvokeMember("Name", BindingFlags.SetProperty, Nothing, font, New Object() {font.Name}) range.GetType().InvokeMember("Size", BindingFlags.SetProperty, Nothing, font, New Object() {font.Size}) End Sub ' Write string to cell Public Sub SetValue(ByVal range As String, ByVal value As String) range = WorkSheet.GetType().InvokeMember("Range", BindingFlags.GetProperty, Nothing, WorkSheet, New Object() {range}) range.GetType().InvokeMember("Value", BindingFlags.SetProperty, Nothing, range, New Object() {value}) End Sub ' Write string to cell Public Sub SetValue(ByVal row As Integer, ByVal col As Integer, ByVal value As String) Dim strRange As String = ColumnString(col) + row.ToString() Range = WorkSheet.GetType().InvokeMember("Range", BindingFlags.GetProperty, Nothing, WorkSheet, New Object() {strRange}) Range.GetType().InvokeMember("Value", BindingFlags.SetProperty, Nothing, Range, New Object() {value}) End Sub ' Set cell value using format Public Sub SetValue(ByVal row As Integer, ByVal col As Integer, ByVal value As String, ByVal format As String) Dim strRange As String = ColumnString(col) + row.ToString() Dim Range As Object = WorkSheet.GetType().InvokeMember("Range", BindingFlags.GetProperty, Nothing, WorkSheet, New Object() {strRange}) Range.GetType().InvokeMember("NumberFormat", BindingFlags.SetProperty, Nothing, Range, New Object() {format}) Range.GetType().InvokeMember("Value", BindingFlags.SetProperty, Nothing, Range, New Object() {value}) End Sub ' Set cell value using format Public Sub SetValue(ByVal address As String, ByVal value As String, ByVal format As String) Dim Range As Object = WorkSheet.GetType().InvokeMember("Range", BindingFlags.GetProperty, Nothing, WorkSheet, New Object() {address}) Range.GetType().InvokeMember("NumberFormat", BindingFlags.SetProperty, Nothing, Range, New Object() {format}) Range.GetType().InvokeMember("Value", BindingFlags.SetProperty, Nothing, Range, New Object() {value}) End Sub ' Set cell value using format and culture Public Sub SetValue(ByVal row As Integer, ByVal col As Integer, ByVal value As String, ByVal format As String, ByVal culture As CultureInfo) Dim strRange As String = ColumnString(col) + row.ToString() Dim Range As Object = WorkSheet.[GetType]().InvokeMember("Range", BindingFlags.GetProperty, Nothing, WorkSheet, New Object() {strRange}) Range.GetType().InvokeMember("NumberFormat", BindingFlags.SetProperty, Nothing, Range, New Object() {format}, culture) Range.GetType().InvokeMember("Value", BindingFlags.SetProperty, Nothing, Range, New Object() {value}) End Sub ' Set cell value using format and culture Public Sub SetValue(ByVal address As String, ByVal value As String, ByVal format As String, ByVal culture As CultureInfo) Dim Range As Object = WorkSheet.[GetType]().InvokeMember("Range", BindingFlags.GetProperty, Nothing, WorkSheet, New Object() {address}) Range.GetType().InvokeMember("NumberFormat", BindingFlags.SetProperty, Nothing, Range, New Object() {format}, culture) Range.GetType().InvokeMember("Value", BindingFlags.SetProperty, Nothing, Range, New Object() {value}) End Sub 'Merge cells Public Sub SetMerge(ByVal MergeCells As Boolean, ByVal range As String) range = WorkSheet.GetType().InvokeMember("Range", BindingFlags.GetProperty, Nothing, WorkSheet, New Object() {"A1", "G1"}) range.GetType().InvokeMember("MergeCells", BindingFlags.SetProperty, Nothing, range, New Object() {MergeCells}) End Sub 'Set column width Public Sub SetColumnWidth(ByVal range As String, ByVal Width As Double) range = WorkSheet.GetType().InvokeMember("Range", BindingFlags.GetProperty, Nothing, WorkSheet, New Object() {range}) Dim args As Object() = New Object() {Width} range.GetType().InvokeMember("ColumnWidth", BindingFlags.SetProperty, Nothing, range, args) End Sub 'Set text orientation Public Sub SetTextOrientation(ByVal range As String, ByVal Orientation As Integer) range = WorkSheet.GetType().InvokeMember("Range", BindingFlags.GetProperty, Nothing, WorkSheet, New Object() {range}) Dim args As Object() = New Object() {Orientation} range.GetType().InvokeMember("Orientation", BindingFlags.SetProperty, Nothing, range, args) End Sub 'Set Vertical cell alignment Public Sub SetVerticalAlignment(ByVal range As String, ByVal Alignment As Integer) range = WorkSheet.GetType().InvokeMember("Range", BindingFlags.GetProperty, Nothing, WorkSheet, New Object() {range}) Dim args As Object() = New Object() {Alignment} range.GetType().InvokeMember("VerticalAlignment", BindingFlags.SetProperty, Nothing, range, args) End Sub 'Set Horizontal cell alignment Public Sub SetHorisontalAlignment(ByVal range As String, ByVal Alignment As Integer) range = WorkSheet.GetType().InvokeMember("Range", BindingFlags.GetProperty, Nothing, WorkSheet, New Object() {range}) Dim args As Object() = New Object() {Alignment} range.GetType().InvokeMember("HorizontalAlignment", BindingFlags.SetProperty, Nothing, range, args) End Sub 'Set Cell format Public Sub SelectText(ByVal range As String, ByVal Start As Integer, ByVal Length As Integer, ByVal Color As Integer, ByVal FontStyle As String, ByVal FontSize As Integer) range = WorkSheet.GetType().InvokeMember("Range", BindingFlags.GetProperty, Nothing, WorkSheet, New Object() {range}) Dim args As Object() = New Object() {Start, Length} Dim Characters As Object = range.GetType().InvokeMember("Characters", BindingFlags.GetProperty, Nothing, range, args) Dim Font As Object = Characters.GetType().InvokeMember("Font", BindingFlags.GetProperty, Nothing, Characters, Nothing) Font.GetType().InvokeMember("ColorIndex", BindingFlags.SetProperty, Nothing, Font, New Object() {Color}) Font.GetType().InvokeMember("FontStyle", BindingFlags.SetProperty, Nothing, Font, New Object() {FontStyle}) Font.GetType().InvokeMember("Size", BindingFlags.SetProperty, Nothing, Font, New Object() {FontSize}) End Sub 'Set text word wrap Public Sub SetWrapText(ByVal range As String, ByVal Value As Boolean) range = WorkSheet.GetType().InvokeMember("Range", BindingFlags.GetProperty, Nothing, WorkSheet, New Object() {range}) Dim args As Object() = New Object() {Value} range.GetType().InvokeMember("WrapText", BindingFlags.SetProperty, Nothing, range, args) End Sub ' CONVERT COLUMN NUMBER TO STRING '(e.g.: col_no 27 returns "AA")'by Si_the_geek (VBForums.com) Function ColumnString(ByVal Col_No As Integer) As String 'Only allow valid columns If Col_No < 1 Or Col_No > 256 Then Return String.Empty Exit Function End If '<--added If Col_No < 27 Then 'Single letter Return Chr(Col_No + 64) Else 'Two letters Return Chr(Int((Col_No - 1) / 26) + 64) & _ Chr(((Col_No - 1) Mod 26) + 1 + 64) End If End Function ' GET ROW AND COLUMN OF LAST CELL Public Function GetLastCell(ByVal WorkSheet As Object) As Integer() Dim RowCol As Integer() = New Integer(1) {} Dim xlCells As Object = WorkSheet.GetType().InvokeMember("Cells", BindingFlags.GetProperty, Nothing, WorkSheet, Nothing) 'xlCellTypeLastCell Dim Range As Object = xlCells.GetType().InvokeMember("SpecialCells", BindingFlags.GetProperty, Nothing, xlCells, New Object() {11}) Dim ColumnMax As Integer = Convert.ToInt32(Range.GetType().InvokeMember("Column", BindingFlags.GetProperty, Nothing, Range, Nothing)) Dim RowMax As Integer = Convert.ToInt32(Range.GetType().InvokeMember("Row", BindingFlags.GetProperty, Nothing, Range, Nothing)) RowCol(0) = RowMax RowCol(1) = ColumnMax Return RowCol End Function 'Set row height Public Sub SetRowHeight(ByVal range As String, ByVal Height As Double) range = WorkSheet.GetType().InvokeMember("Range", BindingFlags.GetProperty, Nothing, WorkSheet, New Object() {range}) Dim args As Object() = New Object() {Height} range.GetType().InvokeMember("RowHeight", BindingFlags.SetProperty, Nothing, range, args) End Sub 'Set border style Public Sub SetBorderStyle(ByVal range As String, ByVal Style As Integer) range = WorkSheet.GetType().InvokeMember("Range", BindingFlags.GetProperty, Nothing, WorkSheet, New Object() {range}) Dim args As Object() = New Object() {1} Dim args1 As Object() = New Object() {1} Dim Borders As Object = range.GetType().InvokeMember("Borders", BindingFlags.GetProperty, Nothing, range, Nothing) Borders = range.GetType().InvokeMember("LineStyle", BindingFlags.SetProperty, Nothing, Borders, args) End Sub 'Read cell value Public Function GetValue(ByVal range As String) As String range = WorkSheet.GetType().InvokeMember("Range", BindingFlags.GetProperty, Nothing, WorkSheet, New Object() {range}) Return range.GetType().InvokeMember("Value", BindingFlags.GetProperty, Nothing, range, Nothing).ToString() End Function 'Close Excel Public Sub Quit() oExcel.GetType().InvokeMember("Quit", BindingFlags.InvokeMethod, Nothing, oExcel, Nothing) End Sub 'Dispose Excel Public Sub Dispose() Implements IDisposable.Dispose Marshal.ReleaseComObject(oExcel) GC.GetTotalMemory(True) End Sub End Class End Namespace
can you provide sample code for reading and writing data to Excel (32 bt) from AutoCAD 64bit using XML extensions that you mentioned.
The point of using the XML is that you don't need Excel on the machine you are running the code. The OpenXML sdk let's you read the native xlsx file without Excel.
There's is example code where you download the SDK (http://msdn.microsoft.com/en-us/library/bb448854.aspx).
You just need to create a reference in your project to DocumentFormat.OpenXML.dll
the connection to an Excel-file is also possible with OLEDB. So if you don't need to modify formating of Excel-cells, you just want to access the data within the tabels, OLEDB can access XLS-files like database & tables.
Samples could be found >>>here<<<
HTH, - alfred -
