I'm using Civil 3D 2014 to return an objectID collection of polylines from the active document. Once I have the collection I am passing it along with the document database to the function below. The function opens an existing document and then performs a WblockCloneObject of the polylines into the newly opened document.
This function works about have of the the time. The other half I get an Access Violation when executing the WblockCloneObject statement. I've included the link to the Autodesk source document from which I adapted this function.
Anyone have any ideas or suggestions?
Rod
'''''''''''''''''''''''''''''''''''''''''' ' Adapted from: http://docs.autodesk.com/ACD/2013/ENU/index.html?url=files/GUID-E02A8AAF-61FF-4C72-8960-0AEEBBEC2594... ' ' objIDCol is created from Civil 3D Corridor.Baseline.FeatureLineMap.FeatureLineCollection.FeatureLine.ExportAsPolyline3dCollection() ' Public Function CopyObjectsToNewFile(ByVal outFileName As String, ByRef docSourceDB As Database, ByRef objIDCol As Autodesk.AutoCAD.DatabaseServices.ObjectIdCollection) As Boolean Dim docMgr As DocumentCollection = Application.DocumentManager Dim docDest As Document Dim docDestDB As Database CopyObjectsToNewFile = False If IsNothing(docSourceDB) Then MsgBox("Source document database is nothing") Exit Function End If docDest = DocumentCollectionExtension.Open(docMgr, outFileName, False) If IsNothing(docDest) Then MsgBox("Cannot open " & outFileName) Exit Function End If docDestDB = docDest.Database '' Lock the new document Using acLckDoc As DocumentLock = docDest.LockDocument() '' Start a transaction in the new database Using acTrans = docDest.TransactionManager.StartTransaction() '' Open the Block table for read Dim acBlkTblNewDoc As BlockTable acBlkTblNewDoc = acTrans.GetObject(docDestDB.BlockTableId, _ OpenMode.ForRead) '' Open the Block table record Model space for read Dim acBlkTblRecNewDoc As BlockTableRecord acBlkTblRecNewDoc = acTrans.GetObject(acBlkTblNewDoc(BlockTableRecord.ModelSpace), _ OpenMode.ForRead) '' Clone the objects to the new database Dim acIdMap As IdMapping = New IdMapping() docSourceDB.WblockCloneObjects(objIDCol, acBlkTblRecNewDoc.ObjectId, acIdMap, _ DuplicateRecordCloning.Ignore, False) '' Save the copied objects to the database acTrans.Commit() End Using '' Unlock the document End Using CopyObjectsToNewFile = True End Function ' ''''''''''''''''''''''''''''''''''''''''''
Hi Rod,
I have tried the following code snippet and it worked ok in AutoCAD 2014. I do not have Civil3D installed in my system, so haven't tried it in that.
Can you please try this code snippet in Civil3D and see if the crash is reproducible ? The entities to be cloned to the new database can be selected when prompted.
Imports Autodesk.AutoCAD.ApplicationServices.DocumentCollectionExtension <CommandMethod("CopyObjectsBetweenDatabases", CommandFlags.Session Or CommandFlags.UsePickSet)> _ Public Sub CopyObjectsBetweenDatabases() Dim acObjIdColl As ObjectIdCollection = New ObjectIdCollection() '' Get the current document and database Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database Dim acEd As Editor = acDoc.Editor Dim selectionRes As PromptSelectionResult selectionRes = acEd.SelectImplied ' If there's no pickfirst set available... If selectionRes.Status.Equals(PromptStatus.Error) Then ' Ask the user to select entities Dim selectionOpts As PromptSelectionOptions = New PromptSelectionOptions selectionOpts.MessageForAdding = vbLf & "Select entities to copy : " selectionRes = acEd.GetSelection(selectionOpts) End If ' If the user has not cancelled... If selectionRes.Status.Equals(PromptStatus.OK) Then Dim SelSet As SelectionSet = selectionRes.Value() ' Add all the objects to copy to the new document For Each ID As ObjectId In SelSet.GetObjectIds acObjIdColl.Add(ID) Next End If If acObjIdColl.Count = 0 Then Return End If '' Change the file and path to match a drawing template on your workstation Dim sLocalRoot As String = Application.GetSystemVariable("LOCALROOTPREFIX") Dim sTemplatePath As String = sLocalRoot + "Template\acad.dwt" '' Create a new drawing to copy the objects to Dim acDocMgr As DocumentCollection = Application.DocumentManager Dim acNewDoc As Document = acDocMgr.Add(sTemplatePath) Dim acDbNewDoc As Database = acNewDoc.Database '' Lock the new document Using acLckDoc As DocumentLock = acNewDoc.LockDocument() '' Start a transaction in the new database Using acTrans = acDbNewDoc.TransactionManager.StartTransaction() '' Open the Block table for read Dim acBlkTblNewDoc As BlockTable acBlkTblNewDoc = acTrans.GetObject(acDbNewDoc.BlockTableId, _ OpenMode.ForRead) '' Open the Block table record Model space for read Dim acBlkTblRecNewDoc As BlockTableRecord acBlkTblRecNewDoc = acTrans.GetObject(acBlkTblNewDoc(BlockTableRecord.ModelSpace), _ OpenMode.ForRead) '' Clone the objects to the new database Dim acIdMap As IdMapping = New IdMapping() acCurDb.WblockCloneObjects(acObjIdColl, acBlkTblRecNewDoc.ObjectId, acIdMap, _ DuplicateRecordCloning.Ignore, False) '' Save the copied objects to the database acTrans.Commit() End Using '' Unlock the document End Using '' Set the new document current acDocMgr.MdiActiveDocument = acNewDoc End Sub
Balaji
Thanks Balaji,
This does not work for me. I've inserted the snippet from the first problem I'm running in to. The acDocMgr.add method raises an error. There is no Add member of Autodesk.AutoCAD.ApplicationServices.DocumentCollection.
'' Create a new drawing to copy the objects to Dim acDocMgr As DocumentCollection = Application.DocumentManager Dim acNewDoc As Document = acDocMgr.add(sTemplatePath)
Hi Rod,
Does your code have this import statement ?
"Imports Autodesk.AutoCAD.ApplicationServices.DocumentCollectionExtension"
I have attached the sample project that works ok in AutoCAD 2014.
Please try this and let me know if you still have the crash.
Balaji
