• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    *Expert Elite*
    Re: Problem with PaletteSet location in Autocad
    11-20-2012 01:19 AM in reply to: ZK_BUDiKOM
    have you found that blog:
    >>>Database.ThumbnailBitmap returns Nothing when called for a side database<<<?
    I think that will be the answer.
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Please use plain text.
    Active Contributor
    11-20-2012 02:31 AM in reply to: alfred.neswadba
    Hi alfred,
    I have no idea what is wrong in this project :smileyhappy:
    I changed like this:
    public System.Drawing.Bitmap get_image_of_file(string filename)
    //create a new database instance and load the dwg file into it.
    Database dbb = new Database(false, true);
    //dbb.ReadDwgFile(filename, FileOpenMode.OpenForReadAndAllShare, false, "");
    dbb.ReadDwgFile(filename, FileOpenMode.OpenForReadAndReadShare, true, "");
    MessageBox.Show(filename);
    //grab the thumbnail bitmap and get rid of the white background
    System.Drawing.Bitmap preview = dbb.ThumbnailBitmap;
    // preview.MakeTransparent(System.Drawing.Color.White);
    return preview;
    and it did not work. Error is the same.
    Messagebox show me path to DWG file - is correct.
    But I thank you for your patience and help :smileyhappy:
    My control "Palette" look like:
    in AutoCAD (during run & debug), my Palette look like:
    no label.control, no background.color - This is weird, do not you think?
    Maybe I do something wrong in other place?
    regards
    *Expert Elite*
    11-20-2012 10:06 AM in reply to: ZK_BUDiKOM
    do you have an older version of AutoCAD? I did test the attached project in debug-mode (with AutoCAD 2010) and it shows the preview icon. Update the references and verify it on your system.
    -.alfred -
    Alfred NESWADBA
    Active Contributor
    11-20-2012 11:56 PM in reply to: alfred.neswadba
    Hi Alfred,
    I don't have AutoCAD2010, but I did test in AutoCAD2012.
    It's work good, but... I noticed that some of the blocks are correct, others do not.
    In attached are two blocks: 2010 not read, 2011 read.
    Maybe here is the problem, not in program?
    regards
    *Expert Elite*
    11-21-2012 01:27 AM in reply to: ZK_BUDiKOM
    the 2010.DWG is a definition of a dynamic block, so when you open this drawing you get the question like that.
    When opening your block with your preview-tool I get then this exception:
    makes me thinking that opening a dynamic-blockdefinition is not supported yet by the API (at least with AutoCAD-2010).
     In this case I would understand some difficulties to querying the thumbnail from the db-object.
    But the 2011.DWG does work with your preview (at my workstation/with AutoCAD 2010).
    - alfred -
    Alfred NESWADBA
